200+ woodworking book reviews
Storing Kiln Dryed Lumber in a Garage
Bart Goldberg
Bart Goldberg
>I'm about to set up a lumber storage rack system in my unheated garage to store some of my lumber. It is all kiln dried wood. Is there any reason to sticker it if its already dry, or can I just stack it on top of itself?
Thanks
Bart
Re: Storing Kiln Dryed Lumber in a Garage
JKJ in East TN
>The word from the sawing and drying forums in the past is if it's dry you do not have to sticker it, just pack it tight. This will even help keep it from gaining moisture as fast as it might otherwise in an unconditioned space.
Tricky question, Bart
>Just to inform yourself, if you have a moisture meter, go into your garage and take some readings on wood that has been there for a year or more. This will give you an idea of where the EMC of that KD lumber is likely to settle after being stored in that particular environment. What you will probably find is that at this time of year, the EMC is around 12% in your garage. That qualifies in the "air dry" range, and probably means you will want to bring it into a heated or climate-controlled space (or a solar lean-to or some other passive kiln environment) to bring the MC back down to a usable range, depending on the time of year that you plan to use it.
Regarding dead stacking vs stickering, you should be fine with the dead stack, but be aware that the boards on the top (and to a lesser extent, the bottom) layer are going to pick up moisture more rapidly than the boards in the middle of the pile, so you could end up with some unfavorable moisture gradients in those boards that you wouldn't have in a stickered pile.
Isn't wood moisture fascinating? :-)
Bart Goldberg
Thanks JKJ!!!
Bart Goldberg
Bart Goldberg
Re: Tricky question, Bart
Bart Goldberg
>Thanks Ellis,
BTW - is there any advantage to treating the ends with Anchorseal while stored in the unconditioned garage?
Bart
Not at this point
>Anchorseal is best used to seal the endgrain of wood that is still green. By now, your lumber has already split as much as it is likely to at the endgrain.
Joseph Mulherin
>Ellis is correct in his anticipating moisture getting into the top and bottom boards more readily than the middle ones. I would suggest putting down pine boards on the bottom and lay pine boards on top to absorb the most of any moisture, and then clamp them on the ends together with a long pipe clamp. Then when you are ready to use any of the wood it will be as dry as it will ever be and be straight and not warped.
The best and easiest way is wrap it in plastic.
Keith Newton
>Bart, If you are not going to be going through it all of the time, the best thing to do is to wrap it up in plastic. This will keep it from changing totally.
