Wax - any wax - offers little protection
Forrest Addy
>Cast iron is very susceptable to rust. Wax - any wax - offers little protection from rust. About the most you can expect from wax alone is as a low friction coating. Waxing to prevent rust is at best ineffective.
If you have a rust problem you actually have a humidity problem. You need either a reduction of relative humidity, some kind of active corrosion inhibitor, raise the local temperature about 30 degrees above the ambinet dewpoint. or a treatment that lowers the surface Ph of the cast iron to 4.5 or so.
If the shop is located with the home laundry you're running a foot race wearing sho shoes. Between the bleach fumes and the humidity your saw table doesn't have much of a chance.
A dehumidifier in the shop is a good start. A better start is to separate the shop from humidity sources seal oof from high humidity ambient air and either air condition or dehumidify the space.
Assuming that dehumidification, separation etc s out; when the shop is idle a light spray of the table top with LPS2 or LPS3 rust preventative will actively prevent rust. You will have to clean and re-wax your saw table whenever you need it.
Tenting the saw with a thick blanket and a 150 watt light bulb underneath will raise the saw table temperature are enough above the dewpoint to prevent rust.
Lowering the surface PH of the saw table requires a protective coating like Parkerizing.
Wherever you have bare dry cast iron you will get rust so you might as well reconcile yourself to it. Learn the remedies and the cures. They all take time and/or are expensive.
