wire mesh/& remotes
wire mesh/& remotes
wire mesh/& remotes
mike mcnerney
>Does anyone know if a tv/audio remote will work through certain wire mesh? The one on this job is from richeleiu #47-39-26-106. It is a fairly tight 'aluminum' weave, & it will be painted. I was going to hold it up & try it before I go to the trouble to install in the door frames.
thanks
Mike McNerney in ottawa
Re: wire mesh/& remotes
Grant Smith
>Should work fine. Most remotes are infrared, or "invisible light". So as long as you can send light through the material, it should work fine.
Regards,
Grant in Iowa
Bill White
>Two types of remotes about which I know. "LINE-OF-SIGHT" and "RADIO FREQUENCY". RF will work through the wall, and LOS has to have clear view of the receiver. Most times the mesh will not interfere with LOS.
There may be newer types of remotes out there. I just don't know, but when we design entertainment centers we have to be aware of the homeowner's equip.
Bill
John McGaw
>An IR (infra-red) remote, the most common kind, should work through the mesh but, depending on its density, the range will probably be reduced. This could be more problematic if the control will be some distance from the equipment or if there is excess room light which tends to desensitize the IR receiver.
Lee Gordon
Lee Gordon
>As others have said, IR remotes ought to work if they can "see through" your wire mesh. Radio frequency remotes should also work provided you don't line the compartment with the mesh. If it's only in the doors, the radio signal should be able to "go around" and penetrate the wood-only part of your cabinet.
