Lumber from Trees
Lumber from Trees
Lumber from Trees
Samuel Brooks
>I am about to start a new construction project w/Shop Expansion :-). I will have to take out 3-4 Ash trees that are about 19" across each. They run stright for about 20' before the first limbs. I was looking at some tables and they were suggesting that I would be able to get somewhere in the 300+ bf per tree.
I am in Mid Michigan. How much should I expect to pay for milling and drying? I am looking for a ballpark idea. And is that enought trees to get a person to come out to do the milling?
Thanks in advance.
Re: Lumber from Trees
Ronald Walls
>With the emeral ash borer out an about all the ash trees will be dying out so you may not get that much out of the lumber. Good Luck!! You might just keep them for your on use. ????
Samuel Brooks
>I am planing on them for my own use. I am trying to figure out how much it will cost me do mill and dry them. I was thinking about doing flooring with it.
BTW you would think with the Bug Ash would be down in price but I have not seen much of a decline.
Thansk for the response.
Dale Lenz
Dale Lenz
>You will get 300+ bd.ft. if you are measuring 19" at the top of the 20' end, the small end, inside the bark. If you are measuring 19" at chest height or so, you will get less than 300 bd. foot, actually 150 on the Doyle, but you should get some over-run. Around here portable band saw mill charge about $.25/bd.ft to saw if you have the logs deck up. I don't get my lumber kiln dried, so can not help in that area. Call some sawmills and ask them if they will mess with your volume.
>My FIL is working at a power gernerating plant that is converting to a wood burning operation to use the ash trees that are being cut down because of the ash borer. The price of getting lumber cut varies quite a bit. A full time professional saw mill operator will generally charge more than someone who is doing it as a side income/hobby. You could figure on it costing you about $1 per board foot to get it milled and then dry kilned, but that price can vary a lot. It should be carefully stacked for a year or so before going to the kiln, or if you stack it this fall it should be around 15-20% at the end of the winter and you could take it to a kiln next spring. A number of articles have been posted on logs to lumber, I advise a search of the archives and articles section. For me it is well worth the effort to get my own lumber cut and then air dried: I have not gotten any kiln dried yet.
Samuel Brooks
>Thanks for the reponses.
Al Killian
>I pay $.70 per bdft for it to be cut and dried. I let it air dry for a month or so befor it goes into the kiln.
Re:What we pay in Iowa
Grant Smith
>Early this spring, we had about 1700 BFt of lumber milled, most of it ash. This took a day with a woodmizer and four men to run the mill, handle logs, offcuts, and lumber. Lots of work!
The mill owneres fees were $1 per mile (one way) trip charge plus 25 cents per board foot. We agreed that hitting any metal would be $20 per blade ruined, but none was hit this time. The lumber was stickered and stacked (some in a corn crib, and some at a friend of mines house). I checked on moisture content just a day or so ago and it was between 14 and 20 percent.
The lumber will be moved to a kiln this weeekend, where I'll pay 40 cents per board foot to have it dried to 6-8% or so. The ash will be milled into flooring for $1 per square foot, random widths. The flooring miller figures about 20-30% loss between my 750 BFt of ash and his flooring output due to knots and width differences between my boards and his flooring dimensions (I think his definition of random widths is 2 1/4", 3 1/4", and 4 1/4"). The flooring he produces is what he calls "Amish flooring", which has tongue and groove, and relief cuts on the bottom side but no end milling at that price. Adding end milling is an upcharge. I plan to install a biscuit in the ends of the wider planks as the floor goes down.
So to summarize, logs to dried lumber costs .65 cents per board foot, though I have seen sawyers charge up to $1 per board foot. Then to have it milled into flooring is another $1 with some loss of square footage. Add your time and any incidentals such as acquiring stickers to the costs. I bit the bullet and bought 1x2" lumber on sale at Menard's for the latest haul. Cut them to 4' lengths, painted the ends orange to remind me that they are stickers and they are mine, and will reuse them for a lifetime.
This is the fifth time I have been involved with milling lumber. It is VERY rewarding. Though Ash isn't a pricey wood, I am betting you get some lumber out of the logs that will make you say it is very much worth it. These are the perfect boards that seldom make it to sale in the retail world. And then it is nice to be able to say "This floor is ash and it was milled from trees taken from the property" to guests...worth a lot in my book. Oh, and I also ended up with 250 BFt of Cherry and 300 BFt of Red Oak as my share of the haul.
You can also go to woodweb and use the calculators there to help you determine how much lumber is in a given log, how much it weighs, and so on.
Regards,
Grant in Iowa<---up to my ash in ash
Also call Woodmizer...
Grant Smith
>Call up Woodmizer at 1.800.553.0182 and ask them who operates one in your area. They'll usually give you 2-3 points of contact.
You can also email that question to: infocenter@woodmizer.com
Good Luck!
Grant in Iowa
