Veritas - Innovation in Tools
OT - Refigerator problem
John in MD
>Sorry for the OT post, but you guys always have the answers...
Have a kenmore freezer-on-the-bottom model refrigideezer. This morning, i noticed the fridge part was warm. Figured the kids left the door ajar last nite and if i kept it closed it would chill down OK. Freezer compartment is fine, and still blowing cold air, making ice, etc...
Been 4 hours now, fridge is still running, and the fridge compartemnt is maybe only marginally cooler than it was at breakfast.
Any ideas why one compartment would be warm while the freezer still seems to be freezing OK?
Feel free to email me directly. Thaks in advance for any ideas.
-JOhn-
Re: OT - Refigerator problem
Neal in San Jose
>Funny you should mention this just now. My fridge bit the big one, and my Sunday was spent buying a new one; Monday it got delivered. So, those things are on my mind just now.
A couple of things to look at. Make sure the air vents inside the box aren't blocked with a big milk box or something. Check to see if there is actually air coming out of the vent in the refer compartment. If not, it could be blocked by dust or a "science experiment". The vents could also be blocked by ice building up, which is an indication your defrost cycle either isn't working or isn't set long enough for the humidity in your kitchen. If you have a thermometer, check to see what air temperature is coming out of the vent - it needs to be 35 degrees or less to maintain a temperature in the fridge of 36 or so. If the vents are full of ice, try unplugging the unit over night, or long enough for the ice to melt, then plug it back in and see if it will deliver cold air again.
If the air isn't cold enough, check to see if the coils on the outside of the box, usually on the bottom, but may be on the back, are plugged up with dust bunnnies, missing cheerios and corn flakes, etc. I know the coils are pretty hard to get to, but a long piece of dowell with a tooth brush taped to the end can be used to get to the places your shop vac can't reach.
If these efforts don't work, you may be joining me in buying a new appliance that has nothing to do with making large pieces of wood into smaller ones. Good luck!
Control knob?
Dan Manturi
>There is sometimes an adjustment that says "colder freezer" or "Colder refridgerator". It sends more cold air to the one you select. that know can get hit and changed. Check that out.
Thanks, Looks to be fixed
John in MD
This looks to be the case - I emptied the freezer section and found ice on the back wall - pulled the panel there and the freezer coild were one big ice block... Hit it with a hair drier on low, and cleared the coils, plugged it back in, now its running fine and blowing cold air into the fridge part. Thanks for the help!!
Wait - what about keeping your beer cold?? Isn't that an essential part of woodworking?? (After the tools are turned off, of course!).
Thanks for the help.
-JOhn-
Howard Norman-Prescott, AZ
>I had that problem with my bottom freezer Kenmore a few months ago. Turns out the fan that moves the cold air from the freezer to the fridge had gone out.
Howard
Jim DeLaney, Austintown, Ohio
Re: Thanks, Looks to be fixed
>It'll probably ice up again over the next few days/weeks. It's very likely that either your defrost heaters are shot, or the defrost timer isn't working.
Either way, it'll be about a hundred bucks for parts, or that plus the cost of a service call if you can't/don't want to do the repair yourself.
Good luck!
Jim D.
Ray Newman
>'bout 3 weeks ago, I had the same thimng happen to our Big Amana regfrig/freezer.
The defroster thermostat failed. Part was US$14.00 & service call was $75.00. Local guy did it & he doesn't charge anything if he can't fix it or unit is beyond repair.
It will probably happen again
Stephen in Frankfort KY
>They don't ice up for no reason. Jim or Ray likely have the right answer. The defrost timer cycles the defrost heater on every so often. Usually about every 8 hours of compressor run time. The thermostat turns off the heater when a certain temperature is met. Failure of any of these three would cause the problem. It is most commonly the timer because it is the one with contacts and moving parts to get fouled up but the other two happen with some frequency.
Bummer
John in MD
>Thanks for the additional replies.
Guess I'll need to get the service guy in after all - I was hoping it would fix itself now, but I guess it's more serious....
At least the beer is cold for now.
Thanks for the help, everyone!
-JOhn-
Larry Clinton At Frankfort (Central)., Indiana
>Chances are it is the Defrost timer. Emerson Appliance makes these for most of the manufacturers, I worked for then as an engineer for over 39 years before retirement. They are a simple device - very easy to change. If you have your manual you may want to locate the timer in the unit, obtain a replacement (should cost less than $10 - $15)and change it yourself.
Re: OT - Refigerator problem *LINK*
Kneale Brownson in Northern MI
>Repair Clinic (see link) can tell you how to check for which parts are failing and then sell you parts, generally cheaper than you can get them from the local appliance repair dealer--but not always. I always check both sources before ordering.
Besides the gizmoes that have been mentioned going bad, you also can have a blocked drain where the moisture goes when the defrost system is working. If the drain is blocked, everything will ice up too. Favorite spot for spiders to nest.
Repair Clinic's Fridge Section
Re: OT - Simulate the timer
Bill Turpin in WNC mountains
>The def timer, a 3 inch square, black device, is usually mounted underneath. It has a 3/8" diameter shaft that can be turned with a LARGE screw driver. Slowly turn it, clicks several times, stop turning when compressor stops. Wait fifteen minutes, you should hear sizzling inside the freezer. Then turn it until it clicks and compressor starts. If sizzling is heard, then everthing inside is working fine. Replace the timer, more like $28. You can do this to save food until you can get a proper replacement. Some general replacement timers have a re-arranged connection pattern. That would require some electrical knowledge and the original wiring diagram.
Bill in WNC mountains
NC Refrigeration license #2821
Thanks, Bill!
John in MD
>I think it's likely the timer, given what I've read here and on the samurai appliance forum.
Didn't know the diagnostic steps to use to determine that it really was the timer, though, until your post. I'll dig into it tomorrow, and hopefully this is the problem.
Thanks!
-JOhn-
