Finishing Question...
Rob Hix - King George, VA
>Hey all,
I think this project has produced more finsihing questions for me than ever.
Now that I have a few coats of polyurethane on, there are some places that, when I sand between coats, look like the stain never soaked in. The place manifests itself as about a 1.5 - 2" wide band of lighter wood. When I put a new coat of polyurethane on, It blends it in with the surrounding wood, so it is not a problems.
The big problem is when I am finished and I want to rub-out the topcoats. Even the slightest bit of sanding will cause the streak. I am worried that it will show up after the final rub out.
First of all, what could be causing this?
Second, my last coat of polyurethane went on realt smooth. It hardly needs sanding except around the grain pattern. Do I really need to sand between coats, or can I just put on my last two poly coats and rub-out at the end.
Sorry this is so long, but thanks for the input,
Rob Hix
