Woodworker's dictionary
Joe Pack
>Here are a couple. E-mail if you want more.
BELT SANDER - An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity and/or resiliency of abdominal muscles.
Re: Woodworker's dictionary
Funny stuff
>I seem to recall quite a lengthy list of these daffynitions. They probably are lurking somewhere in the archives, but it is always fun to dust them off. Feel free.
Belt Sander?
>Oh. That would be . . .
Hand-held power tool that cuts grooves and other freeform concave shapes into otherwise flat wood surfaces. Especially useful for giving wood doors and floors that antique distressed, �lived in� look. Also unmatched for establishing just how thin and cheap the veneer is on IKEA furniture.
From a column by Peter Egan…
Rod Peterson -- Ormond Beach
>…in Road & Track. I have the original text, and I also happen to have permission to reproduce from the publisher—cleverly obtained years ago.
Any ideas?
Rod
Re: From a column by Peter Egan�  *LINK*
Tools
>Work Bench: The largest heaviest object in the shop. Has vices sticking out at just the right height to knock your hips off. So heavy it has its own force of gravity, hence "center of gravity" and it is so large that any small object that is dropped is attracted by that gravity to the exact center under it. The precise distance you can not reach with your arm. You should not try this naked, because your dog will decide it a good time to kiss you on the butt and you will raise up suddenly and break your arm.
Bandsaw: As described by my non woodworking son: that tall one with the blade that goes around like this, making the same motion we all make with a sparkler. Mine is a Ouija brand bandsaw with a Moses blade. It just wanders through waiting for directions from some authority higher than myself.
Re: Woodworker's dictionary My Adds
>UTILITY KNIFE: Used to open (and usually slice through the contents of) cardboard cartons delivered to your front door; they work particularly well on boxes containing leather goods.
PLIERS: Primarily used to round off bolt heads and add razor sharp burrs to knurled knobs, they are also handy for crimping allegedly child-proof screw caps on metal cans of various liquids to make said caps completely non-removable by anyone of any age.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire, they are also very handy for starting charcoal grills and fireplaces when you�re out of gasoline.
WHEEL PULLER: A device resembling a 3 or 4-legged steel Tarantula on a mirror which, after its initial use of attempted removal of a pliers-crimped can cap, can be effectively employed to impress the hell out of friends and shop visitors simply by being hung prominently on the garage pegboard.
LEVEL: Affectionately referred to as �The Bubblestick,� it is usually employed after-the-fact to determine the average percentage level of any number of psycho-active substances in the collective bloodstream of a given structure�s original framing crew; that percentage being a function of the resulting slope in floors and departure from vertical of walls.
FRAMING SQUARE: A real-world example of an oxy-moron, they are prominently placed in lumberyard tool displays but sold exclusively to homeowners to perpetuate the myth that one was ever used by the idiot/alcoholic/drug addict who built their residence.
EIGHT-FOOT SPRUCE 2X4: A favorite framing member used in vast quantities by handyman-remodeling contractors with the word �Doctor� in their business name. Most commonly installed in the prized �wet/green� state, they are unsurpassed for producing the ever-popular �undulating wall� effect, and are economical in use because they only require a single toenail at top and bottom.
OIL FILTER WRENCH: One of a family of tools that will not fit the filter on your current vehicle. Often hung compass point fashion around the WHEEL PULLER.
MITER/CHOP SAW: A portable electric cutting tool usually employed to screw up a maximum amount of crown molding in a minimum amount of time while still making near-perfect 90̊ and 45̊cuts.
SELF-RETRACTING TAPE RULE: One of a family of precisely demarcated measuring instruments used to quickly determine the exact length needed to cut an EIGHT-FOOT SPRUCE 2X4 precisely 1 inch too short.
ADJUSTABLE SQUARE: Another real-world oxy-moron, it�s employed by altered-state carpenters to refute any assertion that their work is not square. Also used with a protractor as an adjunct measuring device similar to a LEVEL.
