OT - ???? - wireless router / MS / new DELL laptop
Howard In Toronto
>Hi all -
Thought I'd try posting this laptop/wireless internet access question again.
I want to accomplish three things at once -
- reconnect my wireless router to my desktop
- set up the laptop to access the internet wirelessly
- set up the wireless network using MS software rather than the DELL offerings
The laptop has VISTA and IE 7 on it.
Can anyone give me the blow-by-blow, inch-by-inch fingerstrokes to use the MS software etc to set this up?
Thank you.
Howard
Re: OT - ???? - wireless router / MS / new DELL laptop
Chuck W
>Which brand of wireless router is it?
Tom
>By reconnect your desktop do you mean make it a wired connection? If so, just plug a network cable into the ethernet port in the back of your pc and into one of the 4 (probably) ethernet ports on the router. If you mean connect wirelessly (assuming you have a wireless adapter installed or plugged in the desktop), it will be the same process as with the laptop.
XP's built in network utility is the MS zero configuration utility. Google it and you will find out how to access and turn it on/off if you desktop is to be wireless and if it uses XP.
I'm not sure where to access the utility in Vista. Have you tried just turning on the laptop and making sure the wireless adapter is also turned on? A bubble should pop up saying wireless networks are in range. Then it is a simple case of following directions. If you have security set up on your network you will need that to connect. If not, it should show up as unsecured. Just click on 'connect.'
Jay Hanks
>Howard, On the Dell I got last Thanksgiving it was all pretty much self discovery once you started the wireless part. It went out and found our network, I did have to set up the key but if you do not have a preset key it will do the work for you. I do not have Vista and it may be different.
Beware a Dell program
Tony Shaftel
>I recently had a heck of a time getting my daughter's new Dell laptop to connect to our wireless router. No matter what we tried, every time we rebooted we had to rediscover the router. Turns out the laptop was running a Dell utility that 'protected' us from ourselves: it remembered the first wireless settings we selected (which were no longer correct) and re-established them upon reboot, thereby overlaying whatever changes we had made. Their tech support person finally directed me to remove the utility (whose name I cannot recall) using add/remove programs, and the connection held after that.
