Undersize plywood router bits
jeff
>Hi all
Everytime I use an undersize plywood router bit, the cut is too tight.
If I use a regular size bit (say 3/4") the slot is loose.
I've tried Freud, Carb-tec, and Amana.
Anyone know who makes others with a very small difference.
And yes, I do use my table saw with a dado blade for alot of the cuts I do. This is for special jigs I use for cabinets I build.
Jeff
Re: Undersize plywood router bits
Ray Binnicker
>Try Whiteside. Mine works ok.
Dave Poulin
>It sounds like your router has a runout problem. The collet is not aligned with the motor shaft. I has a couple of Craftsman Routers many years ago that did this.
Chasing a moving target.
Ray Thompson - Middletown,IN
>There doesn't seem to be much quality control in plywood thickness anymore so I quit trying to match it. I use a 1/2" bit for "3/4" and a 3/8" bit for "1/2" and use sleds with fences on both sides. There has been a couple of magazine articles on the subject in the last couple of years.
Ray
>Good Evening Jeff,
I have experienced the same condition from time to time. In my judgement, the problem I had was more related to plywood inconsistency rather than poorly sized router bits and runout. When I get an improper fit, I use a LA block plane and shave a whisker off the edge face of the ply. It generally slips in the slot nicely.
George
Metric, maybe?
Denis Ch�nard, Orl�ans, Ont.
>I've had that problem when routing dadoes for "1/4" masonite. Out of a hunch I bought both the undersize bit and the almost equivalent metric bit. The metric one did fit, not the undersize one, even though the difference was very small.
Something to look into...
DC
Thank you, all good ideas to try.
jeff
I agree, Ray
>If you make your grooves with a standard-diameter bit (we used to use a 3/8" bit for nominal 3/4" plywood) and rabbet a tongue of exact thickness on the mating pieces, you will never have the muss and fuss of trying to match your actual plywood thickness. Plus, to my eye at least, an overlapping joint looks better than one where you are looking down into a groove. The other advantage of the rabbeted tongue is that it is much easier to get dead-on dimensional accuracy, whether or not your groove is machined to the perfect depth, because the shoulder of the tongue determines the spacing for you.
One more, common in industry.
Andrew F in Australia
>Hi Jeff
I haven't read through all the replies, but this is where a barefaced tongue and groove is used to get rid of all the offcuts.
Say you've got a mixture of 18 and 19mm board.
Set a 17mm bit in the router and cut a 17mm housing/trench/groove (also - US term dado fits in there somewhere.)
Get a slotting cutter and set it 17.0mm off a router table, set to cut a rebate (US rabbet) the same depth as the dado (6mm deep)
The two pieces now fit perfectly, and all is well with the world.
I'd suggest this setup as well in your instance - it will give you a predictable result.
Sorry for the late reply,
Cheers,
Andrew
>You could make the jig someone posted several days ago. It was a pair of guides fastened together on adjustable pivots of slides. You just loosen the adjustment and snug it up on the plywood to set the width and then route your rabbets with it and it makes the slots the right width.
You make it by putting your favorite standard straight bit in the router. You fasten two straight edge pieces onto some half inch plywood so that the straight edges are set back slightly more that the distance from the router bit to the edge of the router base. Then run the router down them and trim away the plywood. Now fasten the two pieces together with either slotted connectors or pivot pieces that can be locked securely.
I don't have one, but it may be my next "jig" project. Wish I could draw it for you.
