>Here is a picnic table I recently finished for my daughter and her family. The design came from an old issue of Woodcraft. The plans were pretty accurate, but not perfectly clear particularly on which fasteners to use where. It seems quite sturdy, but then the glue is all new. Once it reaches their home, they will apply at least one coat of water seal before it goes into service. I also have some thoughts should I build another one.
They do look strong and long lasting s you described them at 5ive Barns. I enjoyed our conversation and you and Sue's very good news. Celebrate on that table with a couple strip steaks and some sweet corn.
For what it's worth, I might suggest a different finish to you, one I used on a new wooden patio table/bench set last summer. It is called "One Time Wood Protector." The product is intended for decks (new wood only), and is available through Do-It-Best Hardware stores, plus, maybe, a couple of other sites. I heard about this product on a radio show, "At Home With Gary Sullivan." He has talked about the product for a couple of years at least.
The product is NOT cheap, about $80/gallon, but it is supposedly one of the best on the market. It does not "dry" as solvents evaporate, but "cures" from exposure to ultraviolet light. As such, the product says it should be applied only where it will be exposed to sunlight. Only one generous coat is recommended. In my experience, it took about 3 hours for the product in direct sunlight to cure to a point where it would barely wipe off, but the bottom where it was not exposed to sunlight took far longer. When I realized this, I turned the items over and they cured in another 3 hours or so.
I believe that the product only cures if exposed to sunlight! About a month ago I was messing around in my garden shed and came across the brush and small roller I used with One Time last summer. Both intended to be throwaways, I had stuck them inside a plastic baggie to keep them from drying out between pieces and had absent mindedly just put them up on a shelf when I was putting the lid on the can. (Probably just too lazy to carry them to the garbage can at the time.) Remember that this was a year ago...they were still wet with the product! The bag was not sealed, just stuck the brush and 3" roller inside the bag with the top still open. Like I said, I DO believe that UV light is required for curing!
The company and Danny Sullivan say the product will stand up to deck traffic for a minimum of 7years (their guarantee is 7 years), far longer in tests. I can't vouch for the 7 years, but I can say that my table and benches look the same today that they did last year, compared to a neighbor's deck that already looks terrible after only one year (he wasn't about to pay that much money for a deck sealer...he must like refinishing decks).
The product is available in natural, a redwood kind of color and in a clove brown color. I read somewhere that the colored varieties will last longer, but I don't know that for a fact.
Anyhow, I am a satisfied customer! If I had an outside project to do, and if I could make sure the product received sunlight, I would not hesitate to use it again. As lazy as I am, I will pay the extra money.
The link below is to a gardenweb forum where the product is mentioned. You can do a search for One Time Wood to get the company web page.
