ADVERTISE HERE - FREE TRIAL
this is how stupid I have become
Tom Sontag - St. Louis
>Two full days in the shop this weekend. Everything was going pretty well til midday Sunday.
First day, after a quick cleanup and business related shop chore, I resawed some spalted sycamore for a new box. This board had a couple of long meandering black lines that made a very unique and interesting pattern along its length. When you resaw such a board you have a bookmatch which goes from side to side or end to end. Matching end for end means that it is possible to line up the four sides with an unbroken black spalt line going around the box, all four corners showing an unbroken design. I spent the first day preparing these boards with trim on each edge and laminating up the bottom with shop cut cherry veneer.
Next day clean up the trimmed sides, thickness exactly in the drum sander, cut groove for bottom, install shelf runners for trays that set in box, etc. Ready to finally cut the 2 pieces into four and glue it up.
The two side pieces get cut in roughly a one third/two thirds ratio, the box being longer than it is wide. So I set the two pieces end to end and visualize where to cut. Move boards one further in front of me than the other and draw my line on each with chalk. Miter the boards to length. Dry fit to check the fit of the bottom and miters. Examine. Attempt to see unbroken meandering spalt line despite clamps which hide a portion of the corner. That's okay cuz this corner's just right. And so is...WHAT?! No matchee! The next one's fine, the fourth a bust! I must have cut the side boards wrong and got uncomplementary "L" shapes or something!
Sit down. Breathe. Figure out what happened.
Must have flipped something (physically or mentally) when I moved the boards around for marking. If I only end up with two matching corners, the whole beauty of the piece is ruined! Relax. After a while I accept fate and decide to complete it as is. The wood is awesome enough to not abandon it. Walk away for a bit and do some yard work. Come back.
Do more fitting and sanding and other stuff and dry fit it again (this is maybe two hours later). Hey, wait a second. All four corners match! What the...?
I obviously cut the sides correctly after all and simply had the ends reversed on the first dry fit. The upper spalt line on two corners matched up by coincidence and made me think I had the correct fit, the lower spalt line being covered by clamp faces.
Okay, the story has a happy ending since the box is glued and in clamps and looking according to plan. But those two hours of defeat I suffered soley because I could not think of exchanging end pieces will weigh on me for some time. Perhaps more so since I approach one of those milestone birthdays.
Hope you enjoyed your weekend.
Fresh from the clamps:
Photo Sharing and Video Hosting at Photobucket
Re: this is how stupid I have become
Re: Happens to all of us
Chuck Lenz
>Tom, that Looks pretty darn good. Atleast you took the time to think it out and didn't scrap the project. Very nice.
>Glad you got the happy ending. Man that is a spectacular piece of wood. Nice work. I probably would have glued it up wrong and then been really mad at myself. The smart move was to walk away without rushing into a mistake.
Which milestone are you approaching? (None of my business. So don't answer) I am 58. How old would you be if you didn't know how old you were? I understand what you are saying, I often feel I don't think as well or as quickly as I used to. Sometimes I think and think and hours or days later the obvious occurs to me, sometimes after I have done the not so obvious. I look and look for things and later find them in plain site. (gremlins) Been considering painting each of my tools an outrageous unique color. 40 and even 50 did not faze me, but 60 is looming large.
(I posted a question on door panels and grain pattern. I would value your opinion, I admire your work and design sense. Would you take a look and tell me what you think?)
>Good Morning Tom,
First, that is a wonderful piece of wood. I never worked with sycamore, let alone the spalted stuff. Its always better to walk away for a time rather then erupt/react. That could have resulted in a far less happy outcome. Lovely box.
George
Ernie Miller
>Nice!
Todd O. Cronkhite Maine Native, Presently Away
>tom, you're betting yourself up way to hard. Trust me, these things happen all the time, and I can easily see where it could happen while trying to line up all those ends. If you was really stupid you'd of either tossed the pieces, destroyed the pieces, or just settled for good enough and completed the box even tho the ends the didn't match as intended, but instead SMART you walked away, came back later and retried it, and ultimately came up with a beautiful piece of Functional Art. That I think you should see in this box.
-Barry, I have those same gremlins in my shop as well. Just yesterday I was searching for my tape measure and couldn't find it anywhere, then I spotted sitting on my workbench. What really fries me about it is that I specifically bought a bright yellow Fat Max so that it would be easy to find! I spend more Time looking for that danged thing than anything else, tho pencils come in a very close second. I cured the pencil problem by having muliple ones close by, tho the razor knife to sharpen it has usually wandered away. }:~[
T.O.
