Anyone purchase lumber rack storags system?
Bart Goldberg
Bart Goldberg
>I'm in serious need of a place to store my lumber - The storage inside my shop is now maxed out. I'm now needing to store my lumber in my garage (unheated space). I have seen three systems thus far on the internet - a Triton system, a wall mounted system sold by Woodcraft that is a bit expensive and a similar, lower cost system sold by Lee Valley. Does anyone have any first hand experience with any of these systems, and if so, which one. Also, has anyone had the opportunity to compare these systems?
Thanks
Bart
Re: Anyone purchase lumber rack storags system?
Brent in Montreal
>Hi Bart
I have this system from Lee Valley
http://www.leevalley.com/wood/page.aspx?c=1&p=32145&cat=1,43326
It's on a concrete wall attached with Hiltis. I've loaded it to the brim and it could probably hold twice the weight. IMO a great buy.
Howard Norman-Prescott, AZ
>I have the same system, installed the same way, as Brent. I am completly satisfied with it.
Howard
Stuart Hough
>I have the Triton system. It's on sale at Woodcraft this month. I don't have a very extensive collection of wood yet, so I haven't reached the 110 lb. limit for a shelf yet, but it does seem extremely sturdy.
Steven Antonucci
built mine from 2x4's
steve antonucci
>I had storage issues, so I decided to get the floor space back by getting the lumber 6'4" off the floor (I'm 6'1", so it's over my head).
I framed the bays with my tools and benches in mind, and I have 10' ceilings in the garage, so the top height is 8'. Shorts down low, longer stuff up high. I probably have 600 BF in the racks.
Steve
>I have a serious lumber storage problem. I made a rolling lumber storage rack. It has shelves on one sided for longer boards, and the backside is tilted for sheet storage. I can store it against the wall and roll it out to get to the sheet goods.
Nelson
>I have the Triton also and its well made and strong, as stated above its on sale so a very good deal.
Mark Kauder, Phenix City, AL
>Sometimes I love to buy the new gadgets I see in the catalogs, and sometimes, I go low tech.
For my lumber storage in my shop, I went low tech. Pipe flanges attached to the wall studs with two 2-3" 3/8" lag screws, and then screwed in a threaded section of pipe. In my case, I generally have 8/4 exotics that are really heavy. Not a problem or sign of one yet. I am using 1/2" & 3/4" Pipe (depending on where it is and what I putting on it.
It works. It is cheap. I prefer more shelves with less load on each rather than few shelves - easier to get to the bottom board, too.
Mark
Re: Hard to beat this approach: *LINK*
Grant Smith
>Here's a shop shop shot of my approach. The pictures are from my old shop, and I have since tripled the storage space by building an A-frame version to go along with this one.
I think it is hard to beat with a commercial system. You can start storing lumber up high and keep the lower pipes removed to save space.
FWIW,
Grant in Iowa
Storing the Goods
easy and cheap to make a robust system
Bill Tindal, E.TN
>For may years I have stored lumber in a simple arrangement. several thousand feet can be stored in a 4' wide space that goes to the ceiling. Think of building an "H" except the H has several horizontal pieces rather than one. the verticals of the H are two yellow pine 2 x 4's and the horizontal is 1 YP 2 x 4 and they are bolted together with two 1/4" carriage bolts where they join. The verticals go to the ceiling and fasten to ceiling joists for stability. I make the rack 4' wide to accommodate plywood sheets.and space the H's 4' apart to accommodate the common 8 and 12' lengths of hardwood lumber. So you would build 4 of these H's for 12' lumber. I just let 14' and 16' hang over the ends, though I try to avoid these inconvenient to handle lengths.
Paul Sadler
>One way to save dollars on a rack is to use old bed rails of the angle iron type. (90 deg.) I seem to have accumulated about 4 pair from when I buy old beds at Good Will, Salvation Army and other thrift stores to get the maple or other hardwood out of the footboard and headboard; a great inexpensive source for wood! I'll be starting the rack soon and will post a pic of the finished project. I wish I was a welder, but I'm not, so this will be a bolt-up.
John McGaw
>I used the Lee Valley system also. Very effective and it looks strong enough to hang a truck on. At least when piled with an insane amount of hardwood it has never complained. Not cheap but definitely worth the money.
Steven Mellott
>I bought a used gondola shelving system (similar to the ones used in grocery stores). The unit is 8 feet long and includes 5 shelves. It is freestanding and does not need to be attached to the wall. Cost was $10 per foot (total of $80). Each shelf holds several 100 pounds.
sreeb
>I have the woodcraft system. I think I could hang my car on it. Just looking at it and the Lee Valley website, it appears identical to the Lee Valley rack. Has anybody tried to mix and match?
If you buy the woodcraft "set", it is 20% cheaper than the Lee Valley piece price. Woodcraft is offering 10% off and free ground shipping on 7/28. Don't neglect shipping as this stuff is heavy.
The Triton rack is much smaller as well as lighter duty so it isn't very comparable. Note that the Triton kit is half the height and and only two columns. I think you would need at least 3 Triton kits
ed
