Have a question? Ask Woody!
epoxy
epoxy
epoxy
al
>Hi,
Does anyone know about the T-88 epoxy or G-2 epoxy or Tropical epoxy glue by doctor Rot?
I need the best stuff for exotic wood.
Thank you.
A" Blais
Re: epoxy
Re: epoxy
Mike Cutler, Griswold Ct.
>I used T-88 on a Macassar ebony frame. I treated the glue area with acetone prior to epoxy application.
I tried a "normal" epoxy, System 3, and while it held, I was able to pry it apart at the glue joint with a chisel acting as a wedge. The T-88 didn't pry apart.
Re: epoxy
Re: epoxy
al
>Hi,
Thank you for the answer. So T-88 is good with exotic wood like Purpleheart. There is also the G-2 epoxy make specificaly for oily wood. But if you said that T-88 is better, I will try this glue. Do you know the Tropical Hardwood Epoxy Adhesive? : http://www.rotdoctor.com/epoxy/woodrestoration.html
Thank you.
Alex
Re: epoxy
Re: epoxy
Mike Cutler. Griswold Ct.
>Yes I knew about the Tropical Hardwood epoxy from Rot doctor; I;m certain it's a fine product.
I used T-88 because I had it on hand, and the website for System 3 indicates that T-88 is appropiate for oily hardwood application. I'm fairly certain that the West epoxies have a similar product.
T-88 is capable of being mixed in very small qualities. It's a 50/50 ratio and is ideal for furniture applications. It requires no fillers or microballons, they have already been added, so it has great gap filling characteristics.
