Have a question? Ask Woody!
Good table, messed up finish. Any ideas?
Joe Pack
>Plastic and furniture don't mix. I told my sweetheart that, but years ago she insisted on using a clear plastic "protective layer" on top of a sturdy kitchen table for years to protect the top. By the time I convinced her that the plastic was not a good idea, the laquer had softened and turned to an eggshell pattern in several areas, mainly where warm plates would set. So, off came the plastic and, to cover up the mess, on went the flannel-backed vinyl tablecloth.
We just received our new kitchen table today (plastic will NOT touch it!) and the old table is relegated to the basement. But now the spots that were softened and checked look like they grew a beard...all fuzzy. With nothing to lose, I tried a bit of laquer thinner to remove the fuzz and it worked; the laquer was softened and removed, along with the fuzz...along with the stain. Evidently the laquer finish was actually tinted a dark cherry color and sprayed on. The Malaysian woood (looks like some form of mahogony) seems to have no color in and of itself. Where I rubbed fairly gently, the laquer and the color came off.
I don't have a lot of refinishing experience. What little I have had involved using Formby's, which is just about dummy proof and extremely easy to use on flat surfaces such as this. Formby's does, however, leave a bit of the old varnish behind, almost like a seal coat.
What I am wondering is how difficult it will be to add color back to the table top. By itself, the wood is a fairly ugly material. I want to bring it back to the dark cherry finish, but am not sure how to proceed. Lazy as I am, I really would prefer not to have to do any amount of sanding to bare wood. I can do it, but would really rather go fishing or play with my lathe. Any suggestions on how to proceed?
Re: Good table, messed up finish. Any ideas?
>The top first needs to be completely stripped with a methylene chloride based stripper, followed by a wash down with VM&P naptha. When dry, rub smooth with maroon ScotchBrite. Don't use sandpaper. Then stain with a pigmented oil stain like ZAR. When it's dry, rub again with the ScotchBrite. Give it another week to fully cure, then top it with either oil based or water borne poly; couple/three coats. After another week, rub it out with 0000 steel wool and paste wax.
Clint
Thanks Clint
Joe Pack
Re: methylene chloride
Dave Bair, Eaton Rapids, MI
>Do NOT use this in the basement; use it outdoors only. It's effects mimic carbon monoxide, with the same results on your body.
