Help cutting Formica
Roy Anderson
>I am setting my old kitchen cabinets up in the basement for a "mother in law" apartment. I have the old Formica counter top intact, but I need to cut out a segment to make it fit. I don't have a lot of specialized tools. About the best I have is a good jig saw. I'd like to cut out a segment and then join the two pieces back together. I'd like it to look good when I get done. What to do?
Any advice will be appreciated.
Re: Help cutting Formica
>Jig ain't gonna do it for you, Roy. Too Course and "wandering" cut line will preclude any rejoining. You haven't described your old counter, and that would help.
Is this a flat counter or does it have a rounded (rolled) edge?
Does it have an integral back splash?
If this is just a flat piece of mica over the usual chipboard laminate, you can set up a straight cut with a long straight edge and a router with a straight bit (if you have one of those). Mica is very "chippy" and even trying to cut with a good saw blade will leave a ragged edge and will not look good in a rejoin.
Sorry to be so negative, but don't want to get you false hope for using the jigger. List of alternate tools???
Roy Anderson
>The counter has a rounded nose and an integral backsplash. See pic.
I Was Afraid Of That
>A straight-edge router cut will be difficult here because of the backspash. You could set up to route from the underside and then cut the backsplash with a utility knife and a fine hacksaw, but I don't know what you'd be doing with that cut edge.
A jig saw cuts on the pull stroke. I've seen guys do smooth coping cuts with the saw running underneath the top surface (all you see is the blade), but not for a cut that needs to be dead-straight.
What Other Tools do you have, Roy?
Kicker here is that you want a smooth seam surface and edge on the rejoin, and I'm not seeing a way to do that that won't cost you more in time and $$ than a new section of counter would.
mm
Neal in San Jose
>Do you have, or can you borrow a hand-held belt sander? You can get close with a jig saw, but as Mark said, the cut is going to be ragged and not very straight. There are special "down cutting" blades for the jig saw that are pretty common, and work well with "chippy" materials like high pressure laminates. You can also cut from the bottom side with a standard blade, which may be your only reasonable option around the backsplash . The idea is to cut "into" the laminate, which will reduce (but not eliminate) chipping.
After getting the pieces close, but slightly oversize, use the belt sander with about a 120 grit belt to sand to a line. You can also use a fairly coarse file, but the belt sander will be a lot faster. It won't be a factory seam, but if you are careful, take your time and check the fit often, it should be close enough. Sand on a VERY slight angle INTO the particle board to eliminate chipping, and the tendency for the laminate to come up. Sand an angle so that the laminate is just ever so slightly proud of the particle board so when you join the two pieces, it is laminate to laminate, and the particle board to particle board has a VERY small gap. Then use a good silicone caulk to seal the seam. Water seapage is your enemy!
It won't win any beauty contests, but if you stand way back and sorta squint, you won't see it. I've done this on rental properties where the goal was utility over beauty, and the joint held up well for years.
Before you cut it . . .
s.mackay@worldnet.att.net
>with the jig saw take a look at the cross section in the middle. I cut a counter almost what you're doing with the circular saw. It started binding and lagging. It had a steel " shank " running the length of it. From the looks of it it'd be worth your time and faster to go borow a c-saw. Fast & straight. Ooooooorrrrrrrr . . . you could go add one to your bag-oh-tricks ! I use ANY excuse !
>Where do want to cut it?
If you cut through the sink cut-out to shorten it, you only have to join the front lip and backsplash and its much easier that a cross cut or miter.
Many years ago I used to cut them and used the belt sander as suggested, and even turned the beltsander so that it "cut" on the down stroke. Then you need to route in the tee slots for the bolts that pull the joint together.
I would look around for a friendly local counter-top shop and ask them how much they would charge to cut it and join it back together. Certainly a lot less aggravation than doing it yourself.
Edward in Vancouver
>Your local Home Despot will cut counter tops for you, they will charge, but it's pretty cheap, and they use a good saw with a good blade--virtually no chipping.
The thing is, How are you going to join the countertops back together again? How will you make the seam water-tight? Fahgettabout the so-called miter clamps at the local home despot, the best thing is countertop connectors, L.V. sells them, think around $3.00 a piece. What you do is drill a 1/2" deep hole using a 1 3/8" forstener bit on the underside of both sides of the seam, then route a 1/4" wide slot that connects both holes. The countertop connector is made up of two pieces of cast alumimun half-moons, and a bolt. You pop the a half-moon in each hole and tighten the bolt, both pieces of countertop are drawn to each other, and if your edges are clean and flush, you will get a tight seam with a very faint hairline joint, which will stand up to many years of use and abuse.
Roy Anderson
>I need to take out about a foot between the corner and the sink and shorten up the long run. I like the idea of cutting out a new sink hole and cutting out part of the old sink hole. At least that way, the visible seams will be very minimal, covered up by the sink.
I also need to shorten up the return leg by about 8 inches. I'm beginning to think it might be better just to get a new counter top.
Great opportunity to buy circular saw
Craig in SIlverdale
>I've cut counter top like that before. I did use a circular saw with a thin kerf carbide blade. The more teeth the better. OF course I cut the end off, and did not try to join it back together. I cut from the bottom side, after I taped the finish side. Cut the back splash first with the front edge of the counter setting on the floor. Then put it on your saw horses finish side down and back splash toward you. I used a straight edge to guide the saw. I lifted the saw gently at the front to cut through. Turn it over and with luck, when you take the tape off there will be no chipped edges. Take your time and it should work out. Good luck.
Dan Donaldson
>Many of the tops made in that style have a very thin coating on them and are difficult to work with without chipping or damaging them. They are relatively inexpensive. I would think about just replacing it with another of the same style that fits if you don't want to build a new one.
Bill White
>You would better served by taking the top to a top shop where they have a beam saw. Like a super-sized RAS. You'll spend way too much time trying to do it with normal shop tools.
Bill
