THE WOODRAT IS BACK!
Safe way to make outside corner molding?
>I've got a little project which needs some outside corner molding in red oak. The pine molding that they have at the BORG won't do. I'll need about 8' of it or so. I have a router (and table), jointer and table saw.
The molding should be maybe 3/4-1" on the outside.
My initial thought was to sand it more or less to "shape" and then use the jointer to cut a very large rabbet in several steps. I'm willing to listen to any suggestions. I don't want to lose any fingers!
Re: Safe way to make outside corner molding?
>I would start with a board about 1" thick and use my TS to cut a 3/4 by 3/4 rabbet in the edge and then rip off a piece the same as the thickness of the board. Use a good blade and then sand it a bit. You could use your router with a bearing guided radius bit to round the corner or you could just sand them into submission. You could round them on your router table as well.
Re: That sounds reasonably safe; Thanks.
>I knew the jointer wouldn't be that safe. I'll probably use the router table to cut the rabbet though.
>Step 1: In a 3/4" thick board, cut a 1/2"x 1/2" dado along 1 edge.
Step 2: Change out the dado set for a good rip blade and rip your piece with the fence set to give you a wall thickness of 1/4" on the cut-off. The rest of your board will be running between the fence and the blade. Just make sure that you have set your rip fence to leave enough on the OUTSIDE of the blade to give you the 1/4" thickness that matches the amount left "above" the dado.
Step 3: Carefully sand the outside surfaces smooth.
Step 4: Put a 1/16" roundover bit in your router table and "relieve" the 3 outside edges on your new moulding, then sand to final grit.
Note: If your board is thicker (1" +), you'll need to set your dado a bit higher and use the full width of your set. The important thing is to get the wall thickness of both legs of the moulding the same thickness.
Been there, done that. It's easy and safe
See quick scribble in case my words get tangled
Scott Crumpton
>I like Mark's method, but would change the order of the cuts. First, surface and joint the board. Now round over the corner if desired. Then cut a dado down it, 1/4" from the jointed edge. Rip off the dadoed strip with the main board against the fence. The advantage of this method is that the rounding is done with the large board and the two main faces of the molding are finished by the jointer/planer.
