E.C. Adkins Saw
E.C. Adkins Saw
E.C. Adkins Saw
Dan Collins
>Friends: I found an old E.C. Adkins saw at our cabin. It is in pretty good shape, although I am having some trouble reading all the engraving on the side of the blade and someone replaced an original screw in the handle with a non-matching steel screw. Does anyone know where matching original screws could be purchased? Also, is there some substance that would help bring out the engraving. I cleaned it thoroughly with mineral spirits and that helped some, but I still can't read some of it. After looking at an old E. C. Adkins catalog, I think it may be a metal cutting hand saw (#21) based on the shape of the handle and the number of screws, although the blade has a slight curve on the top which doesn't look like the metal cutting saw in the catalog. It has a 10 stamped in the heel, which appears to be the PPI. Thanks for your help.
Re: E.C. Adkins Saw
Re: E.C. Adkins Saw
Marv
>Hi Dan,
Go on eBay and do a search under Tools and Saws. People often sell saw screws. Most of the old saws used pretty much the same kind of screws but you'll want brass ones for your Atkins. You won't find the old style screws available anywhere in stores now days. You also might try to find another old junker saw and use the screws from that one.
Mineral spirits alone won't do much to clean that etch. You'll need to use some 340 grit sandpaper. Get the 3M brand that is black, that's the best. You can sand the whole blade both sides. Start with 220, then 340, then 400. Use a sanding block when sanding directly on the etch. If you use your fingers only you'll mash the sandpaper down into the etch and make it less than it is.
Good luck,
Marv
Re: E.C. Adkins Saw
Re: E.C. Adkins Saw
Ernie Miller
>? It seems to me that allot of Atkins saws has steel saw nuts. If you have an old hardware store in the area that has been around for 20 years or more they may have nuts in a drawer some where. how about a picture of the saw? I like Atkins as I think they stay sharper longer. I have this in my address book listed as Atkins saws but a quick look revieled nothing but you could look harder I may have missed it.
http://www.geocities.com/~mvr1/index.html
