Sort of Interesting OSB Observation?
>I have no idea how they make Oriented Strand Board. I assume it was one piece at a time and that somehow they coated those flakes of wood with glue and put them in layers with their little strands oriented, pressed them into sheets and trimmed the edges.
Recently I was walking under a house that was raised on pilings and looked up at the OSB nailed to the bottom of the joists. I happened to notice two sheets end to end that appeared to be "matched". It was clear that they had been a single piece and then cut apart. They were both full sized sheets. The flakes were lined up in such a way that you could see they continues from piece to piece, exactly as if you had cut a piece in half with a skilsaw and left the two pieces laying where you cut them.
I just thought it was interesting that these two pieces had been manufactured end to end and remained "in sequence" and been installed in the same position they had been manufactured in. Also means they must make it on a more continuous basis adn slice them off the end.
Never mind, I need a hobby.
