liquid hide glue problems
Jeff
>I just looked at a veneered bed that I delivered to a client in February, only to discover that some of the veneer that I laid using hide glue is coming loose.
Most of the veneer was laid up using regular yellow glue in a vacuum press; however, some was ironed on. I used the same method that is used with yellow glue: I painted the glue on my substrate and on the back of the veneer. After the glue dried, I used a clothes iron to lay the veneer onto the substrate. Everything held just fine while the piece was in the shop. Now I'm faced with fixing this in my client's bedroom.
Fixing the bed isn't a problem. I'm more interested in finding out why this happened. Is it possibly a cleaner that has been applied that has penetrated and loosened the bond? Or, was the glue not completely dry, or too dry before I ironed it? Too much heat or not enough? If it matters, I used Franklin's Liquid Hide Glue, and a new bottle at that.
The only real leads I have are that heat and water can be used to loosen a hide glue joint. Additionally, in an archived Woodcentral chat session, I did read that alcohol can be used to make the hide glue's structure crack, which will loosen the bond. Water, heat, alcohol, none of these make sense as likely culprits.
Thanks for the input,
Jeff
Re: liquid hide glue problems
Bob Lemon
>When hide glue dries it retains only a small amount of moisture. When you reheat it, that small amount of moisture flashes into steam and forms dry hide glue foam. It is no longer an adhesive. You may be able to reactivate the glue by injecting some water under the veneer and work it around with a roller, then apply clamping pressure and allow it to dry.
When I use liquid hide glue, I evenly spread a layer of glue on the substrate, apply the veneer and a clamping caul. Then clamp until dry. I work a lot with liquid hide and veneer and I use a hot iron for removing veneer during restoration work.
time to do some Quality Control
Keith Newton
>I suspect that the face of the two glue-line may have only been about 10% ~ in contact which would be easy to break.
When the veneer and glue finished drying, both contracted enough to break that small percentage of contact area. I would suggest that you use the same technique on some practice work, then go at it with a chisel trying to pry it apart to inspect. also rip off strips that you can break. If when you break the strips, they break down your glue-line, you need to work on improving.
Whenever you glue up panels. Always make them a bit larger, then break all of the parts that were cut off of the edges, and examine how they break. If you are making poor glue-lines it should be apparent.
