Sorta OT Quetion About My hands?
>This is related to woodworking I think.
I notice my hands get stiff and I can not make a fist. At least I can't curl my fingers around enough to touch the tips to the "pads".
I'm trying to figure out if this is just "old age" (I'm 58) or if it has something to do with the materials I'm using. Yesterday I worked with treated wood, building a deck rail. Today they are stiff. I have discussed having a walnut allergy and I have noticed it when I work with walnut. I am not sure about other times and materials.
So, does arthritis just creep up on you? Is the stiffness related to just working with my hands or is it more related to some sort of allergy exposure. Is it from touching the wood or from breathing the dust and fumes?
Re: Sorta OT Quetion About My hands?
CARL BARTON
>Berry,
I am 49 and have spent 28 years in the Navy and 23 years on ships. I find that there are days that my feet, legs and hands feel as if they have pins in them or knifes stabbed in them and I have allot of trouble moving around. I get the job done, but at a cost.
The doctors tell me it is a combination of getting older, so much time on ships walking on steel decks and arthritis.
His bottom line is I am geting old, he was just trying to be nice about it.
Carl
Brian in Sandusky, OH
>Well, I'm no doctor, but I'm a drug rep that calls on rheumatologists, so maybe I'm a little qualified.
What's probably happening is osteoarthritis. Essentially, most joints in the body are padded with synovial fluid and cartilage. This acts as a pad and cushion in between joints.
Over time in our lives, the cartilage wears down, and bones start to rub against each other, causing pain and limiting movement.
Like I said...I'm no doctor, and I'm not qualified to diagnose, but this is probably what's going on.
You could mention it to your doctor the next time you see him/her, but there's really no "cure" unfortunately.
JKJ in East TN
>Barry,
This subject is familiar to me - I've had trouble with my hands starting back in the mid 80's. (I'm 57) Fingers started going numb, then later, "trigger" fingers, finger/hand stiffness, and increasing wrist pain. In my case, it was overuse at the computer keyboard (I was at first a hard-core software developer) and mouse (then worked in 3D computer graphics/animation).
My finger numbness stabilized after retiring from the computer, but I still get stiffness in my right hand after working on the lathe, mowing, weedeating, and gripping a steering wheel. In my case, it seems to be related to holding my hands under tension in one position too long, such as holding a mouse or lathe tool for hours. It helps me a great deal to stop every few minutes and stretch. It also helps my fingers and hand if I wear a wrist brace. There are a number of useful hand/finger exercises that may help - a physical therapist/dr or even an internet search might help.
I also have reactions with wood but it is strictly a skin/respiratory issue - unless the skin of your hands is getting swollen/tight causing the stiffness, it's hard to imaging wood toxins affecting the underlying muscles. Pressure treated wood has some serious chemicals, so that might be a different story. (The instructions say wear protective clothing and respiritory gear.)
If your stiffness is accompanied by numbness or tingling, it may be a nerve issue and should be checked by a doctor. A nerve conduction test by a neurologist can check for some nerve issues.
And yes, they told me arthritis can creep up very slowly on you. An x-ray can check for arthritis.
As far as the allergies go, I started on a new set of allergy shots this year. (I did this twice in the past) This doctor included two sets of tree allergins in the mix. It's hard to tell for sure, but after some months of shots I seem to notice a distinct decrease in sensitivity to woods, in particular, eastern red cedar and cocobolo.
Joe in a Cleveland suburb
>Barry.
I have a similar problem when woodworking. If I'm doing anything that requires a firm grip like pushing a board across the jointer, my hands start to hurt real fast. Almost feels like a cramp.
I always figured it was arthritis. 10 years ago I was in the hospital with back problems. I was told then that the arthritis in my back was more than the typical 60 year old. I'm 45. What's it gonna be like when I 60?! I'm doomed...
Like Brian said, probably wouldn't hurt to go see the doctor.
Good luck with it.
Gotta Come To Grips
>Good Morning Barry,
Best thing to do is seek medical attention. Joint discomfort is worth finding out about, and they may be able to alleviate it somewhat thru medication and exercise.
My own arthritic condition has become more pronounced, affecting hips, legs, shoulders and hands. I can't use OTC medicines because they are harmful to persons with reduced kidney function. I still do okay, especially when focused on pretty girls, cold beer, or woodworking. I think that is the real key: keep focused and active.
George
Lee Ohmart
>Get thee to a doctor. (or healthcare professional of your choice) Yeah, it could be arthritis but it could be other things as well. Trained medical providers can not only prescribe medications, they can give you exercises, send you to other providers like surgeons, orthopedists, chiropractors, physical therapists, or suggest alternative remedies. As a practicing pharmacist, I have seen cases where people struggled along trying to be their own doctor or relying on the advice of friends only to end up with the condition getting beyond a point where medical science can help. "A man who has himself as his doctor has a fool for a patient,"
>Of course arthritis can creep up on you.
See a doctor (Rhuematologist or some suitable specialist). If it is arthritis, there are some drugs and OTC materials that can help.
The glucosamine and chondroitin sulfate supplements are supposed to help.
My orthopedic surgeon put me on the supplements to help me with a knee problem. It worked for a while, but I still had to have surgery.
Re: Gotta Come To Grips
Marv
>Hi Barry,
Pressure treated wood can be very dangerous. Not sure if it is still used, but they used to treat wood using arsnic among other chemicals. People have nearly died from it. I was told it is safe now but who knows for sure. Check it out and make sure you know what you are being subjected to.
There are so many things around us trying to kill us, it's amazing any of us are still alive. The terrorists are worrisome but considering everything else that's doing us in, they are a drop in the bucket. Over 55,000 died in auto accidents last year. Around 300,000 died in hospitals for reasons unrelated to why they went in there in the first place. Tobacco related deaths are so high in number we can't even count them. The list of things we die from is seemingly endless.
Geeez, I'm sounding like Chicken Little.
No, it wasn't Chicken Little who crossed the road, she was too scared!
What was the question??
Marv
Joe Pack
>I had "trigger finger" in the middle finger of my left hand for years, but no pain or real problem. Then, literally one day, I had pain in the palm of my hand when trying to make a fist. The next morning the stiffness had spread to all fingers on that hand, but went away when I started using it. A few days later, a bit of stiffness hit the right hand.
I actually had an appointment re: a bad knee the next week, so I asked the orthopedic surgeon about my hands. He took x-rays and said I had severe inflammation, but no significant bone disorder. He recommended an anti-inflammatory, mentioning Aleve. I took the Aleve regularly for a week or so, and the stiffness improved. Now I take a couple when it gets too bothersome, not wanting to use the stuff regularly.
Interestingly, I picked up a really nasty case of poison ivy from handling some log sections for cutting turning blanks...bad enough to go to the doctor for a shot. He gave me a shot and a prescription for a steroid pack. I took the steroid pack as directed for a week. Not only did the poison ivy dry up, but my hand pain was gone! The effects lasted about 4 weeks, gradually wearing off. Now I'm back to the Aleve every now and then.
Getting old ain't fun, but I guess it beats the alternative.
Gee-At 75 I Wish
Ken Oakley-Sunny St. Cloud, Fla.
>Some parts of my body would get stiff- Maybe I will go to Home Depot and buy some pressure treated wood to make a stool to sit on.
Kneale Brownson in Northern MI
>I'm 67 and have had this same symptom after working the hands extra hard for at least half a dozen years.
Wayne
>I January I was building kitchen cabinets for my daughter and prior to that didn't have much problem with my hands. I finished in February and my right hand started getting numb and my fingers on my right hand felt (actually didn't feel) they were numb feeling and when I touched anything they tingled, I really couldn't feel anything just a tingling. Here it is July and they are finally getting back the feeling I think it was some nerve problems, and when I made a fist it felt like my fingers were sausages trying to bend. I think it is a combination of 59 and repetitive motion the didn't use to bother me (either)ha. Well I like the numbness sorta as it beats the alternative if yo know what I mean.
Forget HomeDepot, go to Hooters ;)
Hank Knight
>Wayne, your condition sounds like carpel tunnel syndrome. The nerve supply to parts of your hand passes through a small opening in your wrist called the carpel tunnel. Repetitive motion or other trauma - sometimes just unaccustomed overuse - causes the nerve sheath to rub against the bone and swell. This puts pressure on the nerve and causes numbness and tingling in the hand. Once the trauma stops things usually calm down in a couple of days and return to normal. But in severe cases the nerve can be damaged, and return to normal can be very long or never. There is a surgical cure for it. They go in with special tools and enlarge the carpel tunnel to give the nerve more room. It works and is a permanent fix. I have carpel tunnel problems. When I work hard with my hands, I wake up at night with a burning tingling and numbness in my hands. So far it has gone away in a day or two. I probably need to have the surgery done. One day, maybe.
W T M I  !!!!
Rod Peterson -- Ormond Beach
>Way too much information!
Rod
Ric Taylor
Ric Taylor
>Barry,
I'm 59, and sometimes my fingers are quite stiff. Like all of us I've used my hands a lot and now I have some arthritis. It's not bad enough yet to require medication, but I'm getting there.
I also have arthritis in my feet, from 30 years of jogging. I had to give up the jogging, and now for the first time in my life I have to watch what I eat to keep from gaining weight. That's the hardest part of it all.
Ric
My doc said it was Arthuritis.
Art Silva
That's my buddy! A crass old cuss....
Eddie Pacheco, San Jose, Ca.
Sonny Asburry
>Barry:
I had the same problem about not being able to close the little and ring finger on my right hand about 15 years ago. The knuckle was not smooth like a normal knuckle is. My orthopedic surgeion operated on the little finger which involved removing a growth under the ligament which controls the finger movement.
Imagine it like the cables on a crane and put an obstruction under it at the pivot point.
When I asked him if he could do both fingers at the same time, he said "You'll hate me enough for the pain in one, you don't want twice the pain after the operation".
He was right. It hurt for almost a year.
When I went back for the operation on the ring finger, he told me that when he did the first operation, he did not know what caused it at the time, but since had surmised that it was ("dupertron contractures (spelling?), which is the same thing that occurs with "trigger finger" on the inside of the palm.
Even though he had been a surgeon for about 35-40 years, he had mever seem this on the outside of the finger.
He told me that this condition usually occured from heavy smoking. At that time, I had not smoked for 20+ years.
Now I have the same condition on three fingers on the left hand and in the palm of the same hand, but since I am retired and turned 65 this week, I'll wait until it gets worse.
Sorry this is so long, I hope it helps in some way!
Sonny
