>I have project that I am completing with tung oil for the finish. I'm thinking of applying wax and am not sure how long to wait after the final coat of TO. The instruction on the (Woodcraft) bottle say it's ok to use after 24 hours.
>I don' t know the answer to your question, but here is some additional information that bear on the answer.
In my hands tung oil needs to be renewed several times before a mostly permanent film is established. That is to say that after 24 hours the first coat may look good but after a week it looks dry again. So a second coat goes on and it looks good for two weeks and then it too looks dry. Somewhere around 3-4 coats a permanent film is established.
Hence, if one waxes too quickly it may impact reapplication of the tung oil.
I have only done a few pieces with tung oil. It has its place as a specialty coating but it shouldn't be the only coating one knows how to use.
>If you are referring to real, 100% pure tung oil, it will not make much of a finish. It provides no protection from water, watervapor or abrasion. It is very slow to dry (3-4 weeks), needs to be reapplied frequently to maintain appearence and IMO has an unpleasent long term odor. It's best used as a colorant to pop the grain and then be overcoated with a protective true finish.
As to waxing, wax too provides no long term protection. Water will go right through and it needs to be continually refreshed.
I would recommend using one of the faux "tung oil finishes" like Minwax, Watco or a home brew of equal amounts of BLO or pure tung oil, varnish or poly varnish and mineral spirits. The finish will closely resemble an oil finish but the varnish component will provide so real long term protection and appearence retention.
>I have used a wax application after finishing with pure tung oil for some projects with good results. It really finished off the pieces with a nice luster. While many sources say the tung oil may be cured after 24 hours, I have always waited 48 hours or more due to the number of coats I used, just to make sure. That's not based in anything I've read, it's just me. My rule was 3 coats minimum for stuff that will see light duty, 6 coats for stuff that will be handled moderately and 10 or more coats for table tops and heavily used items like toys or gunstocks. Polymerized or formulated tung oil is my favorite finish for gunstocks. It's very resistant to water getting into the wood of the stock which can cause the stock to move thus possibly changing the point of aim. Pure tung oil is somewhat less water resistant. It's a durable yet flexible finish, too. It's also not real shiney unless you buff it out. When I apply wax with a rag and buff it, the shiney factor goes up. When I apply it with a white abrasive pad or 000 steel wool, that seems to preserve the matte look. Some sources suggest reapplication of more tung oil in the future to keep up the finish. If you've waxed it, you might want to rub it down with mineral spirits or turpentine first to make sure there's no residual wax.
>Thanks all for the advice. A little more info from me might have helped. This is for an audio rack for a customer so it's not going to take a beating. Basically it is wood shelves on an aluminum frame. It's not quite as unartistic as it sounds. BTW it's maple.
The image doesn't quite do it justice. The reason for the inquiry is that I think I might like to get a little more gloss in the finish. It has 6 coats at this point and I think I'm done with the TO.
>The best you will get from pure tung oil is satin. For more gloss you need something with varnish in it. Waterlox is a good wiping varnish and the Original/Sealer has a nice mellow gloss. If that turns out too shiny there is a Satin.
I'd give the T.O. as much time to cure as you can before applying varnish over it, making particularly sure there is no build up of a film on the surface. Tung oil takes a week or more to cure and ideally should be given several days between coats despite the optimism of the Woodcraft label writer.
>For more gloss, your best bet is another application of a gloss finish, like Waterlox Original or Gloss, or even a thinned poly. The original TO would be a good base for Waterlox too.
Wax over tung oil works well, but does take a bit of elbow grease to shine, and is not a durable finish. It is something you'd have to renew now and then, so maybe not suited to your particular application IMHO.
