GROOVED SPINDELS
GROOVED SPINDELS
GROOVED SPINDELS
MARK A ELLIS
>I bought a antique childs high chair, THE back is solid spindels and the legs also, THESE spindels all have a spiral groove deseign on them. AFTER i apply the strriper what would be the best way to clean these grooves ?
THANK YOU
MARK
Re: GROOVED SPINDELS
>Mark I take a thin piece of metal and grind it a little bit smaller than the groove. Then I can use it like a scraper to clean out the remaining junk. If you used a good stripper it goes really fast.
>Good Afternoon Mark,
Dentil picks also work. A tooth brush is also effective but will have to be cleaned/relieved of gunk buildup periodically. I use the toothbrush in water and scrub the length of the spindles, wiping with a paper towel. Best not to use the brush on your teeth the following morning even if you cleaned it the night before. :<)
George
jmohnike
>If the buidup isn't bad, I take a string and tie several knots in it about 1/2 inch apart. I then move it back and forth following the groove, keep applying stripper, you can also use a small dia. wire for thougher spots.
Joe
