Re: Finishing time
Paul Dwight
>Beautiful cabinets, Lee. I really like the look.
Conversion varnish is great on kitchen cabinets but requires that you be very meticulous in mixing and cleaning. It can be kind of intimidating. I personally would not recommend conversion varnish to someone completely new to spray finishing.
Nitrocellulose lacquer looks great but is not durable enough for kitchen cabinets, IMHO. Alcohol and household ammonia will soften lacquer. Heat will soften lacquer. Standing water will leave a water mark.
I like Mark's recommendations. I've sprayed both Fuhr 355/375 and General Finishes High Performance Poly and have been very happy with the results. Both products spray quite well and are good for folks who are learning to spray. Both are very durable. I think they look great. I haven't used the Enduro finish.
I wouldn't worry about using either the Fuhr or the GF Hi-Perf Poly around water. Both finishes cross-link as they cure and, once that process is complete, water doesn't affect the film.
I believe the Fuhr finish is available in a flat sheen, which might help you get the appearance you're looking for. GF Hi-Perf Poly is available in a satin sheen which is fairly low-luster but is certainly not flat -- I suppose it looks more like an oil-and-wax finish. I personally like the satin GF finish. There's just enough sheen to give it that soft-to-the-touch look, but not enough sheen that the finish fights with the wood for attention.
Since you're not looking to change the color of the wood much, I would probably start by spraying a coat of dewaxed shellac. Zinsser SealCoat is great for this purpose. You can add a drop or two of TransTint Amber Additive if the pale SealCoat doesn't give you quite enough color. The SealCoat sprays pretty well out of the can with guns set up for most clear wood finishes. If you use a thinner cut of shellac, though, you might need a smaller needle/nozzle set for your gun.
Once the shellac has dried, you can sand with 320 grit if needed -- VERY lightly, keeping in mind that a single sprayed coat of shellac leaves a very thin film -- and then start spraying your topcoats. You should probably figure on spraying three coats.
If you spray a low-sheen waterbased finish, you may find the flatteners in the finish dry on the tip of the gun and mess up the fan of atomized finish. I keep a small brush with soft bristles in a cup of water and when I stop spraying to shift the workpiece or whatever, I use the brush to quickly scrub the tip of the gun. It only takes a second and it avoids the frustration of discovering that the beautiful spray pattern you had five minutes ago has somehow disappeared.
I'd love to see those beautiful cabinets when the finish is complete. Please post pictures! -- Paul
