Cleaning sanding belts
Doug Ridley
>For some reason I can't get the search function to work. Someone please tell me how to clean belts using simple green. Do you mix it with water and if so what ratio? Also will any other detergent work as well?
Re: Cleaning sanding belts
Ken Oakley-Sunny St. Cloud, Fla.
>I mix about 2 oz. Simple Green in a gallon of water. I have an empty 1 gal plastic pail that I put the belts in after rolling the belts to stand on edge in the pail. I soak them over nite and then rinse. Real stubborn residue I scrub a litle with a copper wire brush and rinse again. Then I hang them to dry. Sometimes I will put 3 or 4 in the pail at one time.
>OK - what's wrong with using the "snot bars" (aka abrasive belt cleaners)? It's quick, easy and you don't have to hang the belts out to dry. True, they can carry some of the abrasive away - but it is not like the belts are like saw blades. They are a consumable.
Doug Ridley
>Thanks, Ken. JL- I use the belt cleaners all the time but eventually my belts get a build up that they don't clean off well. Thought I'd try the detergent method and see how it does.
LOL ! . . . I was in denial over those . . .
s.mackay@worldnet.att.net
>'till ya'll talked me into getting one ! Just seemed over-simple to a born skeptic. They sure do work though. If you use it before the material scorches into the belt. What would you say ? Three times the life of a belt with soft wood ? The blocks didn't " disapear " as fast as I thought they would either. Now I'm wishing I'd have kept all those ARMY Desert Combat boots I pitched over there ! Bet the soles would have worked same-same.
>I think I mixed my Simple Green at what ever the "stronger" ratio is they recommend on the label. Closer to fifty fifty or maybe 1 part in four. I have mine in a plastic gallon jug and soak them at least over night, but I have left some in there for weeks. (OK, I forgot them). These are the strips off my Performax.
I have another container with white vinegar for glue deposits.
I hear the really stubborn stuff may require oven cleaner, but I have not tried that. (Be Careful)
I use the snot bars too, and like them, but this is another whole level of cleaning. The gum rubber does a good job on dust, but I have then sanding some heart pine. One piece of wood through the sander and the belt is so clogged the snot bars just runs away in terror. Simple Green works like magic.
Sounds really stupid, but when you get less than a minute out of a belt that cost $8 to $10 and it takes about five minutes of effort to stick it in and then rinse it, (not counting the waiting time because I do other things like sleeping. Tried sitting and watching, but it did not seem to speed it up.)
I have cleaned about twenty belts in the same batch. I have done one or two belt sander belts and a few ROS disks (they tend to curl up, but it works. Cleans off any remaining sterate though.)
>I clean my belts with the crepe rubber until they won't clean this way. Then I use a file card. It will really clean the belt. I'm sure it hurts it eventually but I've used the same belts quite a bit after cleaning this way.
