How to make round boxes?
Craig
>I want to make a few round boxes, about 6" in diameter, 6" high. I have some 3/8" wacky plywood that I plan to cut into a strip about 20" long 6" wide. I plan to make a 3/4" lap joint on opposite sides of each end, bend it in a circle and glue the lap joint together. Once the lap joint has cured, I plan to veneer the outside to get a nice wood finish on the outside. I plan to make the bottom from a circle piece of hardwood, the same as the veneer. Cut a rabbit around the edge of the circular piece of hardwood so it fits partially up into the cylinder. I plan the same for the top.
How does this plan sound? Will I need some kind of gig to bend the plywood around? Any ideas on how to clamp the cylinder while it dries? Does anybody have experience making these types of round boxes? If so can you share your experiences? Thanks!
Re: How to make round boxes?
JKJ in East TN
>I don't know what "whacky" plywood is, but that radius sounds a bit tight for normal plywood unless a series of clearance kerfs are cut into the inside. With a bit of planning, the kerfs will tighten snugly adding to the strength. I believe I saw a formula in an old FWW mag but it shouldn't be too hard to figure out.
Oh, could "whacky" plywood be that real flexible stuff made for bending? I used to have a piece and it probably could make a 6" diameter bend, but I don't know about the strength - it seemed pretty weak.
Re: How to make round boxes? *LINK*
>Sounds like a round Shaker box. Yes, a jig would be helpful.
You could bandsaw some circular tops and bottoms and bevel them.
You can make a bending jig out of some 2 x 8 (or whatever).
Try the Shaker Box route, I've seen round ones as well as oval ones. I agree with JKJ, the plywood may be too weak. Besides, if you go the Shaker Box route, you won't need to glue any veneer.
Shaker Box site
>Pretty simple to do on a lathe.
I was thinking the same thing
Ron in Drums PA
