OT: Can some one tell me how this works?
Don henthorn
>http://www.learnenglish.org.uk/games/magic-gopher-central.swf
Magic Gopher
Re: OT: Can some one tell me how this works?
Chuck W
>Don,
The answer will always be a multiple of 9, 0 thru 81, after the subtraction is done. So when the symbols appear 0 thru 81 are the same symbol.
Chuck W
>only the multiples of 9 though.
Let me try
Hoa Dinh in Alameda
>Any two digit number ab (in base 10) can be expressesed as 10*a + b (* is multiplication). For example:
43 = 4*10 + 3
17 = 1*10 + 7
40 = 4*10 + 0
add the two digits:
a + b
subtract (a + b) from the original number (10*a + b):
(10*a + b) - (a + b) = 10*a - a + b - b = 9*a
(10*4 + 3) - (4 + 3) = 10*4 - 4 + 3 - 3 = 9*4 = 36
Note that the result (9*a) is always a multiple of 9.
In the table, all multiples of 9 (0, 9, 18, 27, ...) has the SAME symbol.
For every iteration, the web site just changes the table with symbols to further distract you.
Hope this helps.
-- Hoa
Look carefully
>Once you get your answer, look for the symbol on the chart.
Then look carefully and you'll notice that the symbol you chose is repeated.
Whatever two numbers you chose your answer will be either, 18, 27, 36, 45, 54, 63, 72 or 81. You answer will ALWAYS be one of those. Just because of the way the math works.
So look carefully.... each of those possible answers has the SAME SYMBOL.
Does that explain it?
Happy Woodworking!
Shows how much my old brain has deteriorated.
Don henthorn
>When you guys explain it, I can understand it. I realize that just because I understand it doesn't mean that I KNOW it.(G)
wilbur
>That's easy.
It's a MAGIC GOPHER!
