OT--Removing roofing tar
Gary Evans Tallassee, TN
>Hi all,
I'm currently involved in flashing the end of the store roof where it butts up against the brick parapet. Over the years there has been a massive buildup of roofing tar trying to seal the joint. Now I'm cutting a groove in the brick with a diamond wheel in my 4" grinder and putting in step flashing the way it should have been done in the first place.
The diamond wheel will penetrate the tar (an inch thick in places,) but it makes an ungodly mess because it melts more than it cuts. I'm looking for a way to clear a path to the brick so that I'm not throwing molten tar off the blade of the grinder. For some reason that stuff is HOT!
I thought about using my heat gun to soften the tar and scrape it out of the way, but I hesitate to do something that might cause it to catch on fire. We just had one big fire next to the store building. I really don't want to catch the building on fire, too.
Also, I have about 60' to do, so a labor saving method would be preferred. I just need to clear a space through the tar about 1/2" wide so that I can get a relatively clear shot at the brick. I don't mind running the blade through a thin layer of the tar.
Any suggestions would be appreciated.
Gary
