hardwood deck joints
George Hresko
>I am new to this site and looking for advice on two aspects of installing brazilian hardwood decking. I am using 5/4 5.5 inch wide random length decking, and EbTy hidden fasteners. First question, if I use a biscuit joiner, on end butt joints, should the joint still be made over a joist / support member? Second question, we are laying the decking in a 90 degree pattern. That is the deck is L shaped and the decking is running parallel to each side of the deck. What is the best way to make the joint where the boards meet at 90 degrees? I have put in a doubled 45 degree support, however, with the normal twisting of the boards, the two that meet at 90 degrees may not lay flat. I am thinking of using a biscuit jointer, cuttting into the end of the board, and using an EbTy to join the two boards. Is this sufficient? Should I be face screwing instead? Final question; several places recommend using an adhesive between the decking and the supports before using the fasteners / screws. Do you have experience in this area, what do you think? I am concerned that using the adhesive is pretty much a one way solution, and if I would have to take something up, I will need to destroy the 'new' decking. Many thanks.
