Ridgid Saw
Ridgid Saw
Ridgid Saw
Norm Thomas
>I'm about to buy the Ridgid TS-3650 contracter's saw for my workshop! I've read good things about it and know 2 people that own one and they have nothing but good to say about it! My shop is small and I would have to chop about 10 inches off of the rails! That would reduce rip capabilities fron 36" to 26". That's 4 more inches than I have on my present saw! I also own a Shopsmith 500 so I can easily use that for wide rips. Thanks, Norm Thomas, Camillus, NY
Re: Ridgid Saw
Re: Ridgid Saw
Charlie Self
>You might want to look at some offerings of a similar fence at Sears--I think--won't swear to this--they had a 24" model at one time, and there might be replacement parts. I haven't checked recently, but both saws used to be made by Emerson Tools, and some parts were readily interchangeable...make that "a lot of parts" instead of "some." Then, if you ever decide to sell the original saw, you won't take a beating, and might even get an extra buck or two for having the second fence. Check. You may need only the rails.
Re: Ridgid Saw
Re: Ridgid Saw
knotscott
>Hi Norm - I'd guess most wwer's would love to be called "Norm"!
If you're that tight on space that you'd need to cut your rails, I think it'd be beneficial to consider a hybrid saw. The outboard motor on the 3650 takes up alot of space too. The hybrids have the same size table area but have internal motors...less space and better DC. There are several available on the market, some starting at ~ $400.
Re: Ridgid Saw
Re: Ridgid Saw
Norm Thomas
>My old saw is not a problem. It has a Vega fence that I cut the rails down (too much it seemed) and I also had to cut the fence shorter. The saw is a Delta. Anyways the bearings in the motor are shot and I gave the saw to a friend who will repair the motor and give the saw to his son! My daughter bought the Ridgid (with my advice) and last weekend I used it and fell in love with it! I like the blade guard, the transport wheels, the cast wings and the quiet motor. I also see nothing wrong with the fence even though it may not be the equal of the Vega. The Vega has a nice micro adjustment that I will miss. Norm Thomas
Re: Ridgid Saw
Re: Ridgid Saw
Norm Thomas
>My old Delta had an Internal motor & the motor sticking out in the rear of the Ridgid did concern me at first! However where I have the saw has my workbench just behind it & the motor will fit under the bench overhang. It will only be awkward when I have to move the saw but I think I can live with that! The Ridgid is 5 inches wider and 5 inches deeper than my Delta and this is more of a concern! I actually will only know if this saw is the right choice only after I buy it! I did make a mistake there because it just went up in price! Norm Thomas
Re: Ridgid Saw
Re: Ridgid Saw
Bri in Mtl
>What about if you have to make an angled cut? Would the motor not hit the underside of your bench overhang?
Re: Ridgid Saw
Re: Ridgid Saw
Norm Thomas
>Good point! Never thought of that! However I could pull the saw forward for those cuts. I just wouldn't want to leave it there! The actual space I have for the saw is 10' by 7'. But that includes my set up area and my wife's laundry sorting area. What I do now when I need more room is move the saw between my bench and another wall bench that houses my Radial & cut off saw. It just fits and the Ridgid won't! But I can move my Jointer into that area and move a aux & laundry table out of the room and put the saw in that area! If I get the saw, I will do a future posting and truthfully tell how I made out. So far I haven't heard from anyone who has the saw! I also have a 10% off coupon I have to use by Aug 12th! Of course the price increse ate that up! Another thing I like about the Ridgid is the blade has a housing with a dust collector port. My Delta has a home made affair which did a poor job of dust collecting! Norm Thomas
Re: Ridgid Saw
Re: Ridgid Saw
Thomas Williams Columbus Ohio
>This saw consistently gets very good reviews, both on the boards and in the magazines. I do not own the saw, but would consider it if I was in the market for a CS.
I just purchased the Craftsman 22124 hybrid saw, and I am pleased. You might want to take a look at their Orion made line of saws due to your space concern.
