>Hi everyone - I am very new to the woodturning game. I live in the desert southwest and have access to a lot of mesquite wood for turning. Can anyone recommend a sealer I could make myself, which would be suitable for sealing the end grain of newly cut mesquite bowl blanks? It would be nice if it could be made of readily-available ingredients (I don't mind paying for them). And any tips you could give me for applying the sealer to the cut wood would also be much appreciated. I value the experience of others, and I sure do have a lot to learn. Many thanks.
>If you don't mind shelling out about $15 a gallon for sealer, I'd suggest picking up a couple gallons of Anchorseal. Google it if you can't find it locally. My particular (peculiar?) method of using it is to put about a pint of the Anchorseal into a big coffee can. Put a slit in the lid and push the handle of a cheap 3" paint brush up through the slit, so the handle sticks out and the bristles are in the Anchorseal. Presto. Whenever you need a little sealer, just pick up the brush, lid and all, and slap it onto whatever you're sealing, then replace it just as quickly. You might want to seal around the slit with a little duct tape to keep that hot desert air from drying out your Anchorseal.
As far as home-brewed sealers, you might want to try posting on the Turning forum if you haven't already. What you really want is a wax emulsion like Anchorseal. To make one, though, you have to heat your mineral wax (paraffin, ceresin, etc.) and blend it with water and possibly some solvent to get a brushable consistency. I don't advocate any wax-melting advice because too many kitchens have been burned out by woodworkers cooking up their own wax mixture. I used to set a hotplate out in the driveway on a cinder block to melt wax. It ain't worth fooling with.
Maybe some of the chemists in the group can give you a better idea of how to prepare your own home brew....
>Doug I've tried a lot of the gimmicks and homemade sealing methods and it's just plain hard to beat Anchorseal. It goes on easily, is water based so clean up is easy, and isn't any more expensive than most of the other methods.
>Besides the excellent suggestions above, I like to leave my turning woods in the log out in the weather where it gets rained on or even set up a sprinkler until I am ready to use it. I usually keep the ends coated with a latex primer.
Otherwise, You can put wood into a cardboard box, or paper bag. This creates a separate atmosphere around the wood which slows down the moisture loss at a rate which is slow enough for the moisture in the middle to make its way to the surface at about the same rate that it evaporates into the air in the box / bag, then into the outer atmosphere without surface checks.
>I agree with these guys. Don't try to make this stuff yourself. You might start a fire, it takes time, and you may end up with home made crap. I like to make "it" myself, but this is not a smart thing to make.
UC Coatings makes Anchorseal. (try uccoatings.com or Google it) They will sell you a two gallon container at a price break and UPS will deliver it right to you. I think they also give you a quart free with the order. A gallon or two will last a LONG time. I cut five thousand feet of walnut logs and only used about two gallons.
>My mother bought lids and sealing rings to put on jars of jelly, string beans, fruits, etc. when she canned. The lady next door just melted parafin wax and poured about a 1/2" layer on top of whatever she was canning to seal and perserve it. A hot pot of wax spilled on the stove burnt the house down.
Every country store had a big pile of parafin wax bars when I was kid. I don't know when they quit keeping them on the shelf. But you got me to thinking about that and I haven't seen parafin bars on the shelves in years.
