Cutting new concrete shop floor
David W
>I need to extend one of the conduits I buried in my new beautiful 4" concrete floors. I'm talking about cutting a 12" square and then about a 3' channel for the 1" conduit. Should I even think of trying to do this with my worm-drive circular saw and a new masonry blade or should I rent one of the bigger gas-powered units? I realize the circular saw blade won't cut 4 inches, but I thought I could get close enough to break it up the rest of the way. Am I nuts? Any other ideas?
Re: Cutting new concrete shop floor
Stuart Hough
>Save your back, your saw, and your soul and rent the real deal. The industrial concrete saws are made to run at right speed, and the blades they run stay cooler due to the larger diameter. The time saved with the proper tool will be more than worth the money spent for the rental. Just my humble opinion.
Larry Clinton At Frankfort (Central)., Indiana
>I have done it both ways. It can be done with a Skill type saw, but it is a real job. I used to install furnaces and put a gas one in an electrical heated house. I had to cut out the 6" thick concrete floor - a square hole about 18" X 20" - did it with the skill saw, about 15 or so composite blades, and about 4 hours of 2 man work sawing and chiseling. I installed one in my house in a similar floor - remembered the first one I had done - rented a real wet concrete saw, paid about $75 for the rental and blade. Had the job done in about 45 minutes, with very little chisel work. If your time is not worth anything (and you don't value your saw much - cause it will get hot and full of concrete dust), you can do it with the small saw - but I sure wouldn't recommend it as efficient. After buying the blades for the small saw I may have saved $30 - $40, but the switch on the $75 saw never worked right again.
Scott Crumpton
>Depending on what's under the concrete, why do all that cutting? I'd first create my entry and exit holes of the proper size and then tunnel. Start at the larger of the holes and insert a PVC electrical elbow pointed at the other hole. Jam a length of straight PEX tubing down it and work from there. Use either air or water to move the dirt/sand. It shouldn't be all that hard to go 3 feet. Then pull the PEX out with a length of flexible plastic conduit attached or just use the PEX for the electrical.
Paul Kramer
A completely different tack
Paul Kramer
>David,
There seem to be lots of folks with more experience in cutting concrete than I. May I suggest something entirely different? How about putting in a false floor above the concrete? Lay in appropriately sized, treated sleepers 12" OC. On top of that 3/4" plywood. On top of that 1/4" hard board (Masonite). The hard board doesn't dent with heavy machinery rolling over it the way plywood will. After that you'll have all of the freedom in the world to change everything to suit your changing needs.
Good luck with whatever you do,
Paul
Justin Szeliga
>For what you have to do a worm drive w/a $20.00 or $30.00 diamond blade & a shop vac will open it up pretty quick & easy, relatively speaking. If you make a couple of passes, have someone hold a very powerful (Sears 16 gallon) vac very close, & just cut as deep as the blade & bury the conduit in the slab, it should work out fine. Make 4 cuts, crack the waste out w/a chisel, run conduit & pour over it. I have my old 8 1/4" SkilSaw set up to do stuff like that. Works great for cutting out wet bed tile in demo work, & it is MUCH easier to control than a 12" or 14" concrete saw. MUCH easier.
Peace
Justin
I agree with Justin
Keith Newton
>Get a diamond blade. It cuts faster and easier, and will still be good after this job.
Then go to Harbor Freight and get one of those air-hammers with about 10 chisels. The set only cost about $20, but they work great for removing the space between the two outer cuts. You might save yourself a lot of work if you went back with weather-proof romex in a smaller groove, filled back in with topping mix.
I don't know if this would meet code, but that doesn't mean it would be unsafe, and you would not have to go so deep as to compromise the slab.
Renting
>For what it's worth, I rented a Makita gas powered concrete cutting wheel and a Bosch SDS drill for a project several years ago. This was after struggling using other tools (circulars saws and drills). Reduced the time from hours to literally minutes.
From what I recall the drill was $25 and the saw was $35 for 4 hours. Used both of them for less than 30 minutes to compelte the job.
Since then I bought a $400 Bosch SDS drill for convenince, since I needed to use it more often. But my need for the saw hasn't come up again, but when it does I'll be renting that Makita.
When you factor in the cost of the bits and the blades that they supply for free when you rent the tool, you're not paying very much to rent the tool itself.
Simply can't beat using a tool that's designed for the job.
Happy Woodworking!
garybuss
>Rather than making the three foot cut, I might just drill a hole with a core drill and pull flexible conduit. I bore and pull under sidewalks wider than 3 feet without problem. I had a sewer line installed under a slab floor and we never cut anything, just the core hole we pulled into. We probably bored 15' under the slab, no problem at all. Just my .02
JKJ in East TN
>The last two times I did that (I cut out for a drain pipe and trap under a basement shower and again for a grate and drain in a concrete carport), I used an abrasive blade to cut just a 1/2" or so to define the edge, then removed the bulk of the concrete with a different method. I have an industrial-strength hammer drill so I drilled a series of 1/2" holes every so often along the borders then cut out the concrete with chisels chucked into the hammer drill. I used a pointed chisel to break out chunks and a flat chisel to smooth to the line.
This was amazingly fast, far easier (IMO) than trying to cut all the way through the concrete with a saw.
I don't remember the hammer drill costing too much, but it's a wonderful tool to have around.
