Completed Project - Nantucket Bench
Stephen Kirk in Quakertown PA
>I finished up the project I had asked several questions about (thanks again for all the replies). This will server as a coffee table in our den. The top and shelf are spalted maple and the sides and rails are quilted cherry. I gave everything a 3:1 cut of shellac. The maples then just got 4 coats of minwax wipe on gloss poly, while the cherry got a coat of General's warm cherry stain and then 3 coats of Minwax wipe on gloss. The shelf is connected with wedged through tenons. The rails and glued onto the ends and got a Miller dowel on each for more strength. The top is attached with button blocks so it can move if it wants. I'm happy with how it came out. It's easy to just sit and look at the top and study all the patterns. The wood for the top and shelf was destined for the burn pile before I rescued it. The cherry on the sides and rails actually came from Malcom Timbers when he moved.
