Success in bending thin strips
Bill Tindal, E.TN
>First, thanks to all that pointed to the errors in my ways at trying to bend thin strips and thanks for the pipe suggestion that pointed the way to success.
The canning pot was the correct radius. Under the band clamp is the thin strip. The paper is to prevent transfer of old glue soaked into the band from the band to the wood and it also provided an absorbant for water. The bands were tightened, the web sprayed with water and the whole affair put into a 275 degree F oven for 10 min. After 10 min the web was sprayed again to soak it and the pot returned to the oven for another 10 min. Then the pot was cooled and the strips removed,nicely bent. I made no effort to optimize these times.
Next the oven was raised to 550 to prepare for baking the pizza.
By the way, a hand planed surface does not fuzz up when steamed.
