foxfire/woodcentral banners question
Bruce, a MN Galoot
>I use foxfire exclusively. I use Woodcentral exclusively. Maybe I have a problem, I don't know.
Anyhow, when I go to the WC marketplace the banners associated with each of the vendors do not appear, as they do in IE, so I can't get to those website with credit to Woodcentral.
Is there some setting I'm missing?
Thanks
Bruce
Re: foxfire/woodcentral banners question
Works fine in Firefox
>If you aren't seeing the Marketplace banners, it could be because you have your security software set at a threshold that will not let these banners appear, since they are supplied by our adverts program. AT higher security settings, the ads may appear as popups and be excluded by the software. This was recently noted by someone running Norton Internet Security. They changed their settings slightly and were able to view the banners with no trouble. Maybe you don't need the level of protection that is selected.
Meanwhile, I'm still looking into another ad delivery system that won't set off any alarms.
Ellis Walentine, Host
Here's the answer:
Bruce, a MN Galoot
>My son said to try this:
"try disabling the adblock plugin if you have it installed.
tools-addons-highlight adblock and click disable."
It did the trick for me. Banners work now.
Bruce
