>I've finally got real woodworking furniture commissions! A kitchen table and an oak "buffet" shelf.
Next question - should I ask for a deposit? And if so, how much in terms of %? If the client doesn't want them, I could easily sell the table, so there is no loss there. As far as the oak buffet shelf, I could easily convert it to a table, so there isn't really a loss there either.
I haven't really thought about doing this as a business quite yet - but it would make writing off equipment costs easier.
>I never used to "do" deposits but I " ate " to much stuff. While you can PROBABLY peddle it off later you still shunted other things to the slow lane to favor this project. Now-a-days I like %25 up front. I still don't like " being on the hook " but it does keep everybody honestand your client has, at least, a small stake in it. Something else that would seem a trivial matter but clients love is to keep them posted during construction. While we do this because we love it most folks think its majic or alchemy. They're very interested in, not only how their investment is going but in the process. Only rule is that I don't let them see it before its done. Keeps that majic going, don't ya' know. And, let me tell ya', there is NOTHING like getting a check for your own work ! NUTH'N ! Best of luck !
>I think it's expected that the clients will give you a deposit that, at minimum, covers the cost of the materials. You shouldn't have to finance their projects for them. I doubt a materials-only deposit will pose a problem, but if it does I would probably turn down the work -- I would see it as a bad omen of things to come. -- Paul
>But a contract as well. If you start making costly pieces and more customized work, you won't be thinking of what you can do with them if your people flake out. You will want your full agreed upon price, not the comfort of knowing you could use it yourself or take the time to peddle it to someone else.
And under the law, for you to have a valid contract, you need to have an "exchange of consideration", which means money. It could be a buck, but it has to be something for the contract to be valid.
Besides, a reasonable downpayment helps you a bit with material costs as well as the most important factor, and that is making your clients know they are truly committed to the agreement. It helps remind them they have a vested stake in the project and will keep them on board till its completion.
>I require a 50% non refundable deposit. At some non-defined price point I will offer to do a 33% non refundable deposit and 33% due at a a half way point and the ballance due on delivery. I don't always offer to split it into thirds, but reserve this for lengthy projects where I feel I am pushing the clients comfort zone on price. This last bit is a dificult thing to know and should not be confused with what you think is a lot of money.
The bit about non refundable should not be a problem when a client is commisioning custom work. it is standard procedure when having work done at a printers or a cake for a wedding. Comissioning a piece of furniture is an even biger investment of time and materials for the craftsman. Even if you can sell it later it will tie up money for materials and money in the form of labor as well as space.
a deposit for only the cost of estimated materials is putting you in the hole as you will be leaving out the incidental items such as glue, sandpaper, finishing supplies etc. In adition you need to allow for other consumables such as bandsaw blades, router bit and blade sharpening, light bulbs. as well as electricity and heat/AC
>I essentially agree with Howard and Nailshooter: Get an advance that covers materials and phase 1 of construction. 30% usually worked out to be a fairly accurate prediction for me. The overall payment schedule always depended on the scope of work. If it was a big job, spread over several months, you need to work out a "progress payment" schedule, whereby you invoice them at certain intervals for the next installment, whether monthly or when specified project milestones are met.
In the case of your table and buffet shelf, it sounds like only a couple weeks work for a one-man shop, so get your 30% up front and bill the remainder upon delivery.
Regarding the contract, first get rid of the notion that the customer will not want the completed work and you might have to eat it. That is something that happens only in the worst circumstances. The customer has voted his confidence in you, so he/she knows what to expect. For your part, you need to provide contract documents and samples of the wood you will use, finished with your intended finish. Cut the samples in half and have him sign your half indicating his approval.
The drawings are crucial. You need to have the overall dimensions clearly marked, along with accurate representations of any molding details, motifs, etc. that distinguish this piece. On the drawing, always have a list of notes that tell what the material and finish will be, along with any other specifying information that would describe the finished work.
The contract itself doesn't have to be formal; I used to do a lot of business based on friendly letters, handshakes and a clear understanding between me and the customer. I only got burned once and that was by a big shot who scr%*#^ed people for a living. I ended up collecting it all in court, but two years later, minus interest. You only can be awarded interest if you specify a particular rate on outstanding balances, and I had not in this case.
Prepare a business letter to the customer detailing what you are agreeing to do -- in conversational but precise terms -- and how/when you plan to deliver the finished goods. Detail the payment structure (see above), and attach two copies of your drawings, along with your finish samples. Deliver the letter, drawings and samples personally and make sure the customer understands that this is not an experiment that he can back out of for some reason. He only gets to do that if you don't deliver what you said you would, and your repeated attempts to remedy the situation have failed.
Have the customer sign one copy of the letter, one copy of each print, and one half of your sample of the finished wood. Then have him write you a check for the one-third (or whatever) down payment.
Remember to keep this conversational but businesslike. In 99% of cases, customers want to have a friendly relationship with their craftsmen. They want to be able to brag about the work to their friends, and, of course, this is good news for you.
Congratulation's on the commission. It is a pretty exciting thing.
I usually ask for 1/3 of the agreed upon end price. I see that Chico, Lee and Robin all ask for %50. My request for 1/3rd is just a personal psychological thing. I like seeing a larger check when I am finished than what I saw to start :^) But fifty percent is probably a better business practice if you want to establish a routine protocol. I think a tougher question to nail down is not the deposit percentage but getting the overall price estimated and agreed upon. That takes a little experience. I've been doing "paying" work for about 5 years. If I am lucky after about 20 years I'll have it down.
>I use two different schedules; one for furniture and another for kitchen/bath remodel work. If it is furniture (stand alone product); I get a 50% non-refundable deposit with the signed contract and 50% on completion. On remodel projects; 1/3 with the signed contract, 1/3 when I start tear out/installation, and 1/3 on completion.
My contract states that work will only start after all drawings and finish samples are customer approved. I do use email for some approvals of drawings; but never for finish samples. I buy materials with the deposit and allow the wood to acclimate to my shop while drawings are finalized.
I set up a "hidden" web page on my web site that is used for written and photographic updates. This way the customer can check progress whenever they want to know what is going on.
I do whatever is necessary to end up with a happy customer (sometimes it is painful to me); however, every customer that I have had (100's) has recommended me to someone else.
>I do 50% deposit when I'm ready to start work and 50% on delivery usually. The final payment varies with type of customer private clients pay on delivery, furniture that is shipped is payed before shipping and work through galleries I'm payed usually a week later, they make sure they are payed on delivery a mail me a check.
I used to have a formal contract but most of what I use now is a final drawing approved by the client and either a letter or e-mail stating the final specs and approximate delivery date. I've never had problems with being paid.
>Clients love a web page where they can see progressof the project, The gallery I show in likes me to send them pictures which they then put up on the web. It is a great idea and the response is always positive.
I enjoyed meeting with you the other day and talking about your interest in a custom-built entertainment center. I'm glad you liked my suggestions to make the piece out of solid walnut, with raised panel doors and pocket doors for the TV compartment. The finish will be three coats of clear eggshell lacquer.
Per our meeting, I have designed a custom cabinet for your den, and I've included my shop drawings with this letter for your approval. The drawings detail all the materials, hardware and finishes I plan to use for this project. I've also included a sample of the wood and finish.
The price for this work will be $6,500, delivered and installed, and will take approximately 6 weeks to complete. I will need $3,000 to get me started, with the balance due upon delivery and installation. [JL: Alternately, you could ask for something less than the balance PRIOR to delivery, with the balance due upon installation.]
If everything is acceptable to you, please sign and return one copy of this letter and each of the drawings and finish sample(s). [Or you could deliver this package in person and not include this paragraph in the letter. Just make sure you get the signed samples and documentation to bring home with you.]
I look forward to working with you on this very exciting project.
Yours truly,
JL Woodworks, Ltd.
Accepted by .................................... Date...............
>I think Ellis is going on the right lines. You can get so specific on your contracts that it scares people off. I have done that myself. And having been in court before involved in someone else's case, it was unnerving for me to see how easily attorneys will brush off a contract. "Contracts are made to broken", one chuckled. "It's up to me to find out how... that's why I'm here".
The moral of that story that takes many years to learn is that any contract is only as good as the people that sign it.
As one of the attorneys I have used over the years advised me, you need three things for a valid contract:
1) details on specific goods or services to be provided
2) a specific indentification of amount to be paid for same. Always suggested as a part of the amount is a payment schedule, including specific downpayment
3) exchange of consideration (see earlier post)
I always do what Ellis specified as it is part of the identification of the exact goods and services provided. I do not assume anything nor do I let my clients. In the "terms and conditions" section of my contract to drive that point home, I have the following phrase:
"No oral agreement(s) other than those specified in this contract shall be included as part of this contract"
I hate listening to "but I thought..." or "my sister in law's contractor did this or that without us having to ask", etc.
The more closely you define your work and your duties in writing the easier it will be for you to have a good relationship with your clients. It seems to help keep everyone's temperature down in case you wind up at odds over something, kind of like having a written set of rules on how the the work will be handled.
Oddly enough, I have found that many of my clients like a very specific contract as it makes them feel like they are dealing with an experienced professional, but it also makes them aware of what to expect and what is expected. I think it also makes them feel good as I spell out exactly what my responsibilities are to them, too.
