OT Elec Question-related to Cabinets
Howard
>jsut installed new cabinets that I built and added two 50w recessed lights for effect. 2 questions -
1)incoming line voltage is 20A on 12 ga wire. the original switches had short lengths of 14 ga(all copper) connected to the 12 ga and then run to 15 amp switches. I changes all the wiring to 12ga, but is it ok to put a 15 amp toggle switch on a 20 amp line?
2) I added a few 4" square by 1 1/2" deep junction boxes and I see that the NEC allows for 5 12 gauge "individual" wires. I was not clear on the term individual(from an elec pov). In one box I have 2 12/2 lines and one 12/3 joining in the box. These connections are bringing line voltage in and going out to either an outlet or light switches. Does this configuration exceed what should come in this size box.
Thanks for the help, I know it's OT but it is related to putting in cabinets. Thanks for your guidance, I've not closed up so if I need to make changes I can do it.
