There's lots of possibilities for mag starters
Forrest Addy
>The whole idea of a motor starter is to provide safe reliable across the line motor starting, motor over-current protection, under-voltage protection when so porvided, low voltage operator stations, and accidental re-start protection. People are wise to install such undustrial electrical apparatus on their home shop woodworkig equipment. NEMA and IEC rated starters are intended for hundreds of thousans fo full load starts and are very reliable for the protections they offer and they provide means of adding any number of additional electrical contacts to support complex interlock and control circuitry.
There's lots of possibilities for mag starters. There are full blown mag sterters which consists of a contactor, an overload relay, and if you wish a pushbutton control station right on the enclosure. In the small motor applications usited for the home shop a NEMA rated motor starter can cost $200 and up if bought new from an electrical supply house.
Some scrounging and shopping can save you a lot of money.
Don't shy away from a used starter such as a take out from a HVAC shop or a motor shop. So lont as the overload heaters are selected in installed to suit your motor a used starter (cleaned up and inspected, certainly) is as good as a new one and for a lot less money.
There are also integrated motor starters such as this one from Grizzly. It uses magnetic holding so your equipment is protected from inadvertent re-starts if lost power is restored.
Try this one:
http://www.grizzly.com/products/G4571
There are other choices from Grainger and other sources.
