>I'm rebuilding one of my son's cast off computers and have successfully loaded XP. I turned on the updates (ask before doing). It has downloaded SP2 and in trying to install it I get an access denied error about 3/4 through the load. Is there a known file or something that needs a permission change or is it a typical MS cryptic thing that could be in a million places.
Ray
PS - I did get a copy of Ubuntu but it needs a bootable DVD and my isn't so that may be my next question.
>For the sp2, I would follow the recommendation to download the sp2 update as a separate cd and load it that way. I have it, and it works fine.
For the Ubuntu, it will fit on a cd, so you don't have to use a dvd. If you put it on a cd, most computers should boot from it. You may have to adjust the boot order in the bios.
>Access Denied. No further explanation. I tried "express" mode and "custom" and it stops in the same place. Downloading is not an option on my 26K dialup, I will order the cd and then try again.
>Thanks Dan, I hadn't gotten that far with Ubuntu yet but will try that. I glanced at it and it showed the DVD full at 3.97 gig, so I didn't even think about copying to a CD.
>Something weird with whatever you got. The Ubuntu boot iso image is just under 700 meg and thus fits on a data cd. If what you have is over 3 gig, then there is something wrong.
>DON'T let the update program try to install Internet Explorer 7. IE7 has worked for some people but I know of several instances where it has caused major problems, especially on older computers with insufficient RAM. In one case I had to do a non-destructive re-installation of XP from the disk supplied by Hewlett-Packard (you can tell this was an old computer - a system disk came with it!).
