Drive center and live center
Bill Harmon
>My bride found me an old lathe, It is a Craftsman model#149.23871.
It is in workable shape. and the motor works. I am in need of the drive center and live center. Unfortunately the parts are no longer available from Sears. The spindle is 3/4x16 TPI and the tail stock is 1/2x20 TPI. If anybody can tell me of a source for these parts or something from another lathe that will work I would be most grateful. A morse taper won't work. respond to my email if possible. Thanks
Re: Drive center and live center
>Post this question on the Turning Forum (In the red column to the left) and you may get better answers.
I had a Craftsman lathe with a shaft that size and it had a No. 1 Morse taper in both the head stock and tailstock. It was the lathe with a tubular bed about 2" in diameter. If that's the same lathe, Ridged makes a similar lathe now for Home Depot. I would bet the drive centers are interchangeable. There are any number of places you can buy such centers if that is what you need.
Phil Joines Krum, Tx
>If the headstock spindle is hollow it's a #1 Morse Taper. Some of the smaller minis use it. Penn State carries drives in that size.
http://www.pennstateind.com/store/headstock-drive-centers.html
If it isn't it may be easier to make than find one. Cut the shank off a normal drive and weld it to a 3/4-16 nut.
