Where Hardwood Lumber Comes From 10 Selling Timber
Bill Tindal, E.TN
>Part 10- Selling your timber
This section should be read by anyone that owns timber.
First some credits. This was a very difficult section for me to write and if it is clear the credit goes to Richard Jones, Wiley Horne and Ellis for figuring out how to get the Table posted.
If you own a woods some day someone is going to knock on your door and ask to buy your timber. There are three ways to harvest it.
�Clear cutting� removes all the saw logs as well as everything else that can be chipped to make paper. In my area, Tennessee, it takes two generations or about fifty years after clear cutting before another crop of timber can be harvested again. It requires much of this time span for the thicket of new sprouts to thin out and eventually start growing the surviving trees at a normal rate.
A second option is �loggers choice� leaving the decision of what to harvest up to the logger. They will remove anything that they can make money on and leave the rest- trees smaller than 12� diameter and larger trees with no value either because they are defective or there is no market for the species (for example beech). Walnut and cherry trees greater than 10� may be removed. It will be a generation before the woods can be harvested again. ,
�Selective logging� removes the trees someone has decided should be removed. If this person is your local forester then both mature and worthless trees are removed leaving behind young trees to fill the gaps left behind. This forest can be logged again in half a generation.
How should you log your forest? As background for this discussion you will need some information. The following information is current for where I live, eastern Tennessee. The details will change with time and place but the conclusions will not.
As has already been discussed, hardwood logs are measured with the Doyle scale. This measuring system substantially underestimates the volume and yield from small logs, accurately determines the yield from large logs and overestimates the yield from very large logs. As your small trees grow, the measured bd ft in the logs from your trees will increase two ways. First, the tree adds volume by growth. Second, the scale used to calculate the yield �grows� them an additional amount because the difference between what the tree will scale using the Doyle scale and the actual volume of the tree converge as the log diameter gets larger.
In case you missed my discussion of the Doyle Scale in my earlier post the formula is:
bdft = (D-4)� X (L/16) where D = log diameter inside the bark, and L equals the log length.
Let us suppose you have 8 trees that at harvest yield one 16� log from each tree. Four of the trees have limbs on two sides of the trunk. They will grade �S. select�. The other four are limbless and �clear� for the full length of the 16� log. They will grade �P1 Prime�. If you harvest these trees today they will bring, delivered to the log yard, the dollar amounts as shown in Table 1 below. The landowner will get about half this amount and the logger the other half.
Let�s see what happens if the eight trees grow for another 8 years. Let us assume that the two limbs on the 17� diameter tree- #2 in Table 1, didn�t die and heal over so they will still show as defects in the harvested log. But, the limbs on the smaller trees, #4, 6 and 8 in Table 1 died, fell off and healed over, which will normally be the case for young rapidly growing trees. The �+� in Table 1 is my estimate of how much these trees will grow in 8 years. These are not unreasonable growth estimates for poplar in the southern Appalachian valleys, or even oak in good growth conditions.
We see from Table 1 that in 8 years the value of these trees went up nearly 3 fold, not counting whatever price increase there might be for poplar after 8 years! The value received for what were the smaller trees went up even more (see Table 1). This illustration shows why I tell people that their trees are worth more than money in the bank, presuming they stay healthy.
Let us examine why the value went up this astounding amount. The trees grew larger adding bd ft to the measured logs. The grade of the smaller trees improved because the limbs fell off and the limb scars healed over to produce clear, higher grade logs. Finally because of the way logs are measured the logs grew twice- once in the earth, and again because of the Doyle scale used to measure them.
Note: Some people, my wife for instance, seem compelled to quibble with any example. Quibble away with the details of this example but in the end the conclusions will still be valid.
What can we learn from this exercise?
1. Let small trees (trees 3 to 8 in Table 1) grow to improve their volume and grade.
2. Large trees with defects (tree 2 in Table1) don�t add much value with time. Harvest them and make room for better trees.
3. Large good trees (tree 1) add value with time but not as much as small trees. Harvest them if you need the money or if they risk becoming damaged with age.
So, do you clear cut, loggers choice, or selective harvest?
Most everyone chooses 2 in my neck of the woods, a poor choice by my estimation. This choice takes many trees at the peak of their productive growth and leaves trash trees that should be replaced by healthy and vigorously growing trees. It is the equivalent of letting a competitor skim off your most valuable staff.
Your trees are your employees. Make them work for you or get rid of them and �hire� some new ones. If the woods has lots of damaged and/or low grade trees then clear cut it if you can stand to look at it afterwards. Otherwise hire a forester, or get one for free from the state, to evaluate your timber and select trees to harvest.
Re: Where Hardwood Lumber Comes From 10 Selling Timber
more on the Doyle Scale
Bill Tindal, E.TN
>This graph, prepared by the custom software package "W. H. Graphical Wizard" illustrates the convergence of the Doyle scale with reality as the diameter of the log increases.
I think there will be three parts left to cover in the next couple of weeks- where the sawmill waste goes, how lumber price increases as it moves up the food chain to the retail dealer, and drying.
Re: more on the Doyle Scale
Don Orr
>Very interesting Bill. I have been following this series and enjoying it very much. Thanks for all the work it takes to put this together.
Re: Thanks so much for doing this!
>Now if you have any tips for buying the lumber, that would also be appreciated.
Your requests for additional info
Bill Tindal, E.TN
>Your request will be filled in Part 12, on lumber pricing Look for it in a week or so. If anyone else has a special request for more information send them soon as I am about to run out of gas on this project.
Re: Your requests for additional info
Larry Barrett
>Bill
Your series on logging, sawmills, etc has been fascinating.
One topic I am interested in has to do with dead (or dying) trees. Can they be logged or are they passed over? Once a tree (green or otherwise) is cut down, how long can it be on the ground before concern for insect damage?
My limited experience with oak is that insect damage in the sap wood is quick, but takes a little longer for damage to appear in the heartwood. I recently cut up a black oak that had been on the ground for over a year. I split it into parts for chairs, and found lots of useable heartwood (sapwood not used in my chairs).
Regards
Larry Barrett
