replacing jointer knives on Delta 37-190
Paul Waddle
>I've run into a problem trying to change knives-I can't loosen the gib screws! The 8mm wrench supplied(open end) by delta rounded out. I tried an 8mm makita wrench and it rounded out too. The screw heads seem to be ok. Now if I go to Sears and get another 8mm wrench,whats my chances of loosening the screws?? Any suggestions will be appreciated. I'd rather not remove the cutter head-probably run into more problems. Are the gib screws tapped into the gib or is it a clearence hole for the screw to turn in and out? Yep,I've consulted the manual and I'm turning the screws clockwise to loosen-got a couple loose,so I know I'm ok in this respect. Thanks for the long question. pw
Re: replacing jointer knives on Delta 37-190
Bill Tucker
>Had a similar problem. A few drops of Kroil (creeping penetrating oil) on each screw, tap gently, let sit overnight, then used the Craftsman wrench and OK. If you can't find Kroil, any autoparts store will have something to loosen frozen bolts, like PC Blaster. Be sure to clean all of that liquid out of there before the head spins.
bill
Jim DeLaney, Austintown, Ohio
>Do remember that to loosen those gib bolts, you actually 'tighten' them into the gibs - that is, you turn them clockwise, or to the right, to loosen the gibs.
As for the Delta wrench, it's a piece of trash. A good quality wrench will be a vast improvement, although you may find a Craftsman, Snap-On, Mac, etc., to be too thick to fit. You may have to grind it thinner - being careful not to overheat it in the process.
Jim D.
Paul Waddle
>Thanks a lot.pw
exactly
Bill Tindal, E.TN
>That is what worked for me too, including the Craftsman wrench. the useless wrench supplied just rounded over. Follow each step and success will be at hand.
