stapler source
stapler source
stapler source
Jess Bunch
>I am rebuilding more and more stuffed furniture lately and I need a good middle of the line air powered wide crown stapler ..Elect ones dont cut it . None of the Borgs around here Carry anything like I need. Perhaps one of you can steer me in the right direction. Thanks for your participation, Jess
Re: stapler source
Re: stapler source
>You might want to "reverse engineer" this. Figure out what staples you want to shoot and then find the gun that shoots them.
My understanding is that there are several guns ou there that shoot "upholstery" staples.
As far as where to buy the gun, Harbor Freight keeps coming up here. I don't have any of their guns, but they keep coming up here. All of mine are Senco. In my case I got a Senco gun thirty years ago in a used tool store and I am still using it. Since then I have bought five more and had no trouble with any of them other than ordinary wear and tear. I have two half inch crown staplers that shoot staples from 1 1/2 up to 2 1/2" and a 1/4" crown one. You prabably want the wide crwon version of the little one. One thing to check for is the range of lengths the guns will shoot. Soem are pretty stupid, like from 1/2 to 1" and another gun that goes from 7/8 to 1 1/2". Then other manufactuers make one gun to shoot them all. OTOH, If all you want to do is shoot short staples, buy the smaller gun becasue it maybe more compact. Really check that. More compact coudl be a real blessing. Also look at whether you can direct the exhaust air. I can't on mine and sometimes it's a PITA. Also, oilless or oil free guns have come along since I bought mine and that might be really good for you. No chance of oil on the fabric.
Re: stapler source
Re: stapler source *LINK*
Rob Hix - King George, VA
>Jess,
Try the Grex website (www.grex.com). I do not have any experience with their products, but I hear nothing but praises for them. The brand used to be a little hard to find, but I think Amazon carries some of their stuff now. I noticed on their web site they had a lot of staplers.
Hope this helps,
Rob Hix
P.S. As usual, no affilation. Just relaying satisfied customer comments.
Grex Website
Re: stapler source
I have a Harbor Freight
>I have 4 Porter Cable nail guns of various sizes (all nails and brads, no staples). I also have one Harbor Freight brad nailer, the same size/style as one of my Porter Cables.
I think I paid $70 for the PC bradnailer (BN125) and about $14 for the HarborFreight version. The HF one was their $45 one that they often slash the price on. I bought it as an experiment and to comapre to the PC.
Even at $14, I still think it's a waste of money and that the $70 PorterCable is a better purchase and value. It works, but just doesn't seem to be built to last very long. If I were buying tools for one project, then I guess it's a good value, but I don't buy my tools that way.
Guess I'm just very picky.
The HF one hasn't failed or anything, alhough it miss fired a couple of times within the first 50 brads. The PC has never mis-fired once in probably 1000+ brads.
I agree that you should look for the staple you need forst, then get a gun that will shoot it. I've had good luck getting most brads/nails at HD and Lowes, but I've found that Amazon has a great selection and get them there if I can't find them locally.
Happy Woodworking!
Re: stapler source
I'm picky, just like Mark.
Rod Peterson -- Ormond Beach
>Although I wouldn't even experiment the way he did. I bought my daughter a Porter-Cable when she had a small upholstery job she wanted to do, and my local upholstery shop tells me he uses it, as well. He says it just shoots staples all day long, so that's the closest I can come to a testimonial of any kind for it.
When I needed one, I wanted to complement my suite of other Sencos (I now have five), so I bought a Senco SFW08 (I think it is). It's comparably priced to the P-C. I've used it a few times and it certainly seems as adequate as the P-C, but I can't provide professional upholsterer testimony for it.
Either of those is the direction I'd send you, if you had asked. Wait—you did. Good luck in your quest.
Rod
Re: stapler source
Re: Fasco
>Good Evening Jesse,
I did professional part time upholstery work for a time before founding The Colonel's Workshop. My employer had Bostitch staplers, and these worked flawlessly. Most of us who worked in the shop actually preferred the Italian made Fasco because operationally, it was every bit as good, but was smaller and easier to handle. I bought one and still use it 15 years later. In all that time, it never failed. 3/8" crown is what I bought, but all common sizes were available. It was one of the best tools I ever owned.
George
Re: stapler source
Porter Cable US58 thoughts *LINK*
Tim Greif - West of Chicago
>I got lucky and found the Porter Cable fine wire upholstery stapler on sale at Amazon for $39.99. Shoots 22 ga. 3/8" crown staples. At that price it was a bargain. I've used it on a number of upholstery projects and even to install screen material.
It's a nice little stapler. However it does misfire on a somewhat regular basis. By misfire, I mean it fires but no staple is discharged. It's never jammed or malfunctioned in any other manner. You just have to sort of keep an eye on the applied staple area to make sure you've discharged a fastener. I see no way of adjusting anything to correct this. It probably does this 10-20% of the time.
Other than that, it's a good performer. At $39.99, I'll live with it. But I'd think twice before spending $80, unless I just got a fluke. I'd like to hear from other PC users on this.
PC Upholstery Stapler at Amazon
Re: stapler source
Re: stapler source
Larry Clinton At Frankfort (Central)., Indiana
>I am assuming, since you mentioned electric as an alternate, you are seeking a "fine wire" upholstery stapler. I purchased a Senco on the Bay, and have been very happy with it. My son used it to install insulation in several rooms. I have used it on a few small projects. It has never jammed - very rarely misfires, usually only when running out of staples. I would recommend it and would buy another if this one dies. However, be sure you purchase staples when you buy the gun. The borgs don't carry the staples for my gun - standard air staples for upholstery - the only place I found them locally was at a Do-It hardware. They only carried the staples in a 50,000 quantity box. I have a lifetime supply! However, I spent about the same amount for the staples as I did for the gun.
