OT.Any replacement window gurus here?
Virgil
>I have a vinyl replacement window question regarding the caulking on the outside of a replacement unit.The instructions are less than clear and the tech line...well.... On the outside bottom of the window there is a snap in piece that fills the gap between the sill and the base of the replacement window. Should the gap at the bottom be caulked solid along the bottom or should there be a couple 3/8" "weep" (gaps) holes left to let any moisture out that might get behind the window frame? There should not be any water getting back there but someone at work mentioned caulking with a couple small gaps.Most jobs I've "inspected" here in the neighborhood have been wrapped in al. and caulked solid. Thanks
