Re: Fire safety - how to store flammables?
Paul Dwight
>There was a thread on this a month or two back over at sawmillcreek.org. Lots of good discussion.
My understanding of the issue is that the main purpose of flammable liquid storage is to keep a fire that started elsewhere in the structure from reaching, and being accelerated by, the stored flammable liquids. The challenge is somewhat similar to to the fireproofing required between an attached garage and the living space. It seems to me that a good compromise between cost and effectiveness would be to build a closet with 5/8" drywall on the inside and outside of the stud walls. Insulate the stud bays with fiberglass. Hang a solid core door, fully weatherstripped. A storage area like this should give firefighters a pretty long time to bring a fire under control before it ignites the flammables.
The issue I'm most uncertain about has to do with venting vapors that could accumulate inside the storage area. You wouldn't want vapors to accumulate in a sealed area to the point where a spark could touch off an explosion or fire. On the other hand, a vent into the interior of the shop seems like it would create a way for heat and sparks from a shop fire to reach flammable liquids in the storage closet. Venting the storage closet to the outside would probably be ideal. An interior vent might be OK with some kind of a baffle arrangement to protect against sparks and burning embers -- I'm not sure what that would look like.
Hope this helps. -- Paul
