Another finishing question...
Rob Hix - King George, VA
>Hey all,
Back to my topcoat dilemma for my bookshelves. My dad asked me tonight why I did not use sanding sealer over the stain. I could not answer the question because I am not sure of the difference between sanding sealer, polyurethane, and lacquer. Could someone please help me out here?
Also, why not use sanding sealer instead of one of the other finished?
Thanks for the help,
Rob Hix
Re: Another finishing question...
Steve Schoene
>Sanding sealer is finish formulated to predominately to sand easily, often through the addition of chemical soap--stearates. In most cases under NC lacquer, or under single part varnishes, including polyurethane, it is purely an expedient to speed sanding the first coat or two. But it isn't needed. Those top coats are self priming and the sanding sealer doesn't make the top coat adhere better. Too much sanding sealer can end up weakening the overall finish.
There are top coats that require a sealer for best adhesion, but you can be sure that will be spelled out clearly on the manufacturers data sheet or label instructions.
