One of those days ...
Stephen Kirk in Quakertown, PA
>Sometimes it helps just to talk about the bad days. 3 days ago I put the seal coat on the pieces for a bench (which will actually be a coffee table). 2 days I stained the pieces which will get stain (I'm pre-finishing). Yesterday I wanted start applying poly, but it was so humid here in the north east that the stain wasn't dry (it was oil based). By lunch today, it seemed pretty good. Still, when I wiped on the poly, the rag ends up looking like I stained it (I've had that happen over multiple types of stains). The non stained pieces came out fine. I used minwax wipe on poly which normally dries in 2-3 hours. About that time, the non-stained pieces are perfect, but the finish on the stained pieces is still quite tacky. Ugh, will nothing dry right. So, now it's sitting out in the sun, hopefully to dry so that I can wipe on a second coat tonight. Seems to be helping last I checked on the pieces.
Funny thing is I tested the whole process on some scraps and everything dried just fine.
Some days, I guess, these things will happen.
Re: One of those days ...
there is a reason why
Michael Dresdner
>Oil based coatings and stains, most of which are based on linseed oil, contain driers. That's because even a thin coat of raw linseed oil takes about seven days to dry. Driers speed up the process so a thin coat dries overnight.
Unfortunately, high humidity can disable the driers, albeit only temporarily. As a result the finish or stain will dry as if it were made with raw linseed oil.
The good news is that it is not permanent -- once the humidity drops the finish will once again dry as normal. The best thing you can do is be patient and don't make things worse by rushing into another coat before the previous one is dry.
Re: there is a reason why
>Well, that would explain why the sample I did was fine. If the first coat doesn't seem dry enough tonight I'll wait another 24 hours. Hopefully, the single coat of poly and the stain will still dry together. Using the warm sun seems to be speeding things up a bit.
Perhaps it wasn't quite dry enough when I put the first coat of poly on and that contributed to why some of it wiped back off. It doesn't seem to have bothered the look of the finish at all, though. Now that I think about it, if it looked like some stain was wiping off, that means I may have redistributed a bit of stain, which means it has to dry all over again. Oh well, I'm patient.
I'll have to remember this for other cases.
Thanks.
