Does the NEC allow 15 amp outlets to be
Alan Tolchinsky
>used in a 20 amp circuit? I thought I read this somewhere. My house is wired like that so either it's correct or the inspector missed it. Anybody know the NEC on this? Thanks!
Re: Does the NEC allow 15 amp outlets to be
Yes, as long as there's more than one outlet...
John in New Mexico
>I don't remember the section and page, and I'm in Tucson right now so I don't have the book handy, but you have it right.
John
Agree, but I thought..
Brian in Brghton
>that you could put one 15A outlet on a 20A line.
I thought this was the case because a 20A outlet has a different outlet configuration so that you can't put a 20A plug into a 15A receptacle.
Brian in Brighton
Re: Yes, as long as there's more than one outlet..
Rick Christopherson
>A duplex outlet, which is common, automatically qualifies as two outlets so it is acceptable. What you cannot do is place a single, non-duplex outlet on a 20 amp circuit because that is a dedicated outlet on the wrong size circuit.
Even better, thanks Rick
John in New Mexico
One more related question?
Alan Tolchinsky
>O.K. Thanks guys. It looks like it's alright to do. Do you think the 20 amp ones are made better. I hate it when the plastic breaks on an outlet from plugging and unplugging. Are there outlets that will take more abuse? Thanks again.
If the plastic breaks…
Rod Peterson -- Ormond Beach
>…from plugging and unplugging, you're not paying enough for your receptacles. I would expect that from builder's grade receptacles costing about 69¢ apiece.
I can't say this as absolute fact, but I believe the only difference between a 15 and a 20 amp receptacle of similar price is the pin configuration. I don't believe there is any quality difference in them just because one is configured for a higher amperage. As a business model, I can't imagine there is one iota of cost difference in their manufacture.
The receptacles I used in my remodel were near $3 as I recall. They have a back clamp feature which allows you to insert the stripped wire behind the screw straight in from the back and then tightening the screw. Note that these are not the infamous back stab receptacles which have been cussed and discussed here from time to time, and in my opinion, ought to be illegal.
Rod
Re: One more related question?
Larry Clinton At Frankfort (Central)., Indiana
>Depends - I have had high priced ones fail - almost as much as the cheap ones. I personally purchase the cheap 15 Amp & install them. As I installed a whole bunch (approached 100) in my shop, I figured the ones I use a lot may fail, if they do it takes me about 10 minutes to replace them, with a heavy duty (expensive) type. With all the outlets in my shop, I doubt some ever get used much, and some not at all. I use the screws for attaching the wire, never had any "dangerous" problem with any outlets (I have seen the postings lately where there were issues - but don't know the initial quality or type of outlet). Due to the fact they can be changed with little time or cost, I prefer to use the "saved money", to install more circuits and heavier gage wire - both are things that are tough to redo after construction is complete. I have the largest 100 amp entrance available installed in my shop - fed from my house 200 Amp entrance. I used every breaker space in the box. I installed # 10-3 W/G for all 220 V. circuits and 12-2 W/G for all 120V circuits. After 3 years of use I wished I had added a few more outlets in certain places.
Re: If the plastic breaks�
Alan Tolchinsky
>Hi Rod, I like the outlets with the "screw clamps" on them. You don't have to play around with making loops for the screw terminals not that it's that difficult. The screw clamps just seem like a better mouse trap. Thanks.
