Re: Refinishing Wood Floor (PIC)
Kevin Rabenaldt
>Yes, you could hire it done. That is the easiest, but if you want to do it yourself, go for it. I doubt hiring for $2.50 per foot will cut it. The pro will want to finish also if he has done the hard part.
Murphy's Oil Soap may work as described. Just do not use strong solvents because of the fire danger created by the fumes. Flash fires are very easy to create in these conditions. You will need to rid yourself of the majority of the glue. If the oil soap does soften the glue, I suggest using a 4 inch scraper blade that is razor sharp and changed often. Work your 2' x 2 foot area so that you are working in soften glue area. You do not want the glue to harden back on you. For example, in removing vinyl flooring, the technique that works well is to cut out the 2'x2' area with a utility knife, remove the flooring, scrape the glue that is soft down to the base flooring. In your case, you have to soften the glue.
Then you can start sanding. Rent you a machine once all of the glue is gone. Experiment with grit. Do not use any rougher grit that what is required to get started. If one room is worst than other do not start with the rough grit everywhere, just the rooms that need the rougher grit. Also, use the same grit and grit sequence over the entire area of each room to give consistent results.
Be sure and use the stain and finish recommended for flooring. Floor finish is thinner in viscosity so that it will flow out.
Good luck, give yourself plenty of time, and do not get discouraged.
Kevin
