Sounds Like Someone
>Doesn't understand poly finishes. Poly (especially oil-based) goes on pretty thick and can give the impression that it will fill grain and scratches. However, give it a month or two and it "pulls down" onto the surface as part of the curing process. What might have started out as a 6-7 mil newly dry coating winds up as a 2-3 mil cured film that telegraphs any surface defects.
Sand your fuzzies and nubbies off and vacuum clean very well. If you've gone through the shellac in a spot or two, pad on a bit more to reseal, and lightly sand to level any stroke marks. Let dry for at least 24 hours to make sure that all but an extremely minimal amount of solvent has evaporated.
BTW, I'm spoken to several waterborne finish makers and marketers (Target and Jewitt), and they report that they're having problems with cracking waterborne topcoats applied over shellac sealer, especially Zinsser's SealCoat, if the sealer has some age or is too thick. If you're using SealCoat, check the born-on date on the can. If you're mixing your own, make up a fresh batch for this application and run it through a coffee filter to catch any residual wax content that can impair adhesion. Also keep your sealer coat as thin as possible. If, like me, you use shellac to tint and match up variations in color of sections of a piece, consider adding tints to your sealer.
