Adjusting the drum on a Performax 16-32
Brian MacDonald - Olympia, Wa
>I was wondering if anyone has tried a Wixey or Beall angle gauge to adjust the drum on a Performax sander? It looks like it would be an ideal way to do it.
Thanks!
Thanks!
Re: Adjusting the drum on a Performax 16-32
Rob Sandow
>I have a 22 44 Pro and I find that using the set of shims they provide works fine for me. What are the issues you are having with the supplied method?
Rob
>I've gotten frustrated with getting the drum parallel to the table. It seems I always end up with a noticeable line on wide panels. I was wondering if the gauge might make the job a bit less frustrating. Both advertise .5 deg accuracy.
Ian (in Sydney, Australia)
>Brian
If I can do the maths 0.5 degree accuracy translates to about 1/8 inch at the centre of a 32 inch panel.
>1/8"! well, it was just a thought. Thanks for the info.
